    Help with Controller and Keyboard on PIFBA
    6 Posts 2 Posters 3.0k Views
    • O
      orbitall2k
      I'm using PIFBA to run the neo-geo games, but when I enter the game does not work any command, or on the keyboard and not the PS3 controller. Already I edited the file /opt/retropie/emulators/pifba/fba2x.cfg several times, deleted and created based on the template and nothing,
      Allguém have any ideas?
      • herb_fargusH
        herb_fargus administrators @orbitall2k
        @orbitall2k you can try the latest beta as it has an automated script for it.
        • O
          orbitall2k @herb_fargus
          @herb_fargus beta of the RetroPie? or PIFBA?
          Of Retropie i'm using, 4.0-beta2 and regarding PIFBA i try installing from source, but nothing changes.
          as I am using the 4.0-beta2, i'm not sure if is the right location on forum for problems.
          • O
            orbitall2k
            I managed to work !
            I Download PIFBA from GitHub, extracted only the fba2x.cfg file e copy to dicretory of pifba, and works
            wget https://github.com/digitalLumberjack/pifba/releases/download/0.3/pifba-0.3.zip
            sudo unzip pifba-0.3.zip fba2x.cfg
            cp fba2x.cfg /opt/retropie/emulators/pifba/
            • herb_fargusH
              @orbitall2k are you on a pi 1? If you have a pi3 you should use lr-fba-next it works better
              O 1 Reply Last reply Reply Quote 1
              • O
                @herb_fargus I'm on pi3, i will try lr-fba-next so, Thnaks!
