every lr emulator loose frame rate when using shaders.
  • I was able to play every system with shaders but now ( also with old system like snes or megadrive) when using them, I loose a lot of frame rate. I dont know what happened. I aam using gl for video driver and alsa for audio. If I switch on sl12 for video driver, I am not able to select any shader.
    Can you guys help me?
  • Global Moderator
    Only the gl driver supports shaders, switching the video driver to sdl will not get you shaders. What shaders are you using ? What video card do you have - is it powerful enough to run those shaders ?
