    Dialog Boxes contain x's and q"s instead of shading
    dialog box x q
    44 Posts 8 Posters 8.9k Views
      mitu Global Moderator @Aqualime
      @Aqualime For the 2nd error you reported, there is a fix pending, when it will be accepted to the RetroPie-Setup repository you'll only have to update the script.
        brunozero @mitu
        @mitu Thanks a lot, I already turned off the rpb but before turning off I updated the script and apparently the error problem stopped, but tomorrow I confirm, if I still continue I run your solution, thank you very much
        • LolonoisL
          Lolonois
          FWIW the Issue is pending in raspi-config
          https://github.com/RPi-Distro/raspi-config/issues/88
            Well, the issue got fixed in the raspi-config repository, so the next raspi-config release should make the problem go away.
