    RetroFlag safe shutdown config problem
    retroflagpipe symbol
    5 Posts 3 Posters 240 Views
      MikeC
      Setting up my nespicase+ for safe shutdown. It requires dropping into the terminal to execute a command. The command contains the "pipe" symbol. It's on my keyboard but will not appear on screen. Without it, I'm screwed. Is there some Linux trick to make the "pipe" symbol appear? I've tried reconfiguring the keyboard, but no luck. Can't understand why such a simple thing should be such a pain in the butt. Pipe works fine in Windows.
      mituM EfriimE 2 Replies Last reply Reply Quote 0
        mitu Global Moderator @MikeC
        @MikeC Change you keyboard layout to US using raspi-config. The default Raspbian image has an UK layout.
        • EfriimE
          Efriim @MikeC
          @MikeC
          sudo dpkg-reconfigure locales #it is a long list be sure to check "en_US.UTF-8" use TAB key for cursor placement. ISO-8859-1 may be problematic too.
          or
          use key combo "ctrl+shift+u" and type in unicode "7c" and press "enter"
          and
          Goodluck. This is the script I used for my case reset button exits emulator and power switch saves EmulationStation Metadata.
          • EfriimE
            Efriim @Efriim
            Also the pipe symbol means that the command with file in argument is being piped to the next command. So if you wget a file it is saved in your current directory, then you can just run the next command on that file.
              MikeC
              Thanks folks for your great advice and quick response. Making the keyboard change in raspi-config worked like a charm. By the way, I highly recommend this nespicase+ case. Thanks again!!!
