    Doom Legacy - Doom Split-screen Source port
    doomdoomlegacydoom legacysplitscreen
    97 Posts 13 Posters 21.0k Views
      mitu Global Moderator @tpo1990
      @tpo1990 said in Doom Legacy - Doom Split-screen Source port:
      Is it this variable that will force Doom Legacy to run with dispmanx and if so how about on a Pi3B?
      For the Pi3 is not necessary, the test is done against the kms platform flag, which is not set for the Pi3.
      tpo1990T 1 Reply Last reply Reply Quote 1
      • tpo1990T
        tpo1990 @mitu
        @mitu Ah that clarifies it. I do remember reading somewhere that kms is used for the Pi4 platform. Thanks, I will test with dispmanx on my Raspberry Pi4 very shortly and if it works, then update the scriptmodule.
        Greetings from Denmark. :-)
        Developer of install scripts for ports such as Hexen 2, Return to Castle Wolfenstein and Caesar III. See my other projects at my profile.
        • I
          ish @tpo1990
          @tpo1990 yay thx
          • quicksilverQ
            quicksilver @tpo1990
            @quicksilver What Raspberry Pi are you using and is it the latest official RetroPie?
            Have you tried running the scriptmodule again to see if it will build the binary?
            It's a pi 4, I tried several times to get it to build using the latest scriptmodule but I run into the same issue each time.
            Edit:
            Now the build process just hangs after getting sources, might be having issues upstream.
            • I
              ish @quicksilver
              @quicksilver i used the new script on my pi 4 and it runs fine apart from the display issue
              • quicksilverQ
                quicksilver @ish
                @ish weird, I can't get it to do anything now. Won't even start building. I'll have to keep playing with it.
                • quicksilverQ
                  quicksilver
                  So it looks like the problem is that I cant connect to https://liquidtelecom.dl.sourceforge.net/ im not sure what the issue is. If I try from my PC it just says it took to long to respond.
                    mitu Global Moderator @quicksilver
                    @quicksilver Re-try a few times, it's a temporary issue. If it still doesn't work, try replacing it with https://svwh.dl.sourceforge.net/project/doomlegacy/1.48.4/doomlegacy_1.48.4_source.tar.bz2.
                    I quicksilverQ 2 Replies Last reply Reply Quote 0
                    • I
                      ish @mitu
                      @mitu im trying to do 2 player but it recognises both key boards as player one how can I fix this
                        mitu Global Moderator @ish
                        @ish I don't know, I don't have doomlegacy installed.
                        • quicksilverQ
                          quicksilver @mitu
                          @mitu Thank you! Thant worked and the game now builds successfully now. Just forgot to add the dispmanx flag, so will have to do it again lol
                          • quicksilverQ
                            quicksilver
                            except it seg faults with dispmanx. D'oh! :(
                            executing /home/pi/.doomlegacy/config.cfg
                            RequestFullGraphics...
                            /opt/retropie/supplementary/runcommand/runcommand.sh: line 1255:  9525 Segmentation fault      SDL1_VIDEODRIVER=dispmanx DOOMWADDIR=/home/pi/RetroPie/roms/ports/doom /opt/retropie/ports/doomlegacy/bin/doomlegacy -iwad "/home/pi/RetroPie/roms/ports/doom/doom.wad"
                              @quicksilver What happens if you start with an empty config ?
                              • quicksilverQ
                                quicksilver @mitu
                                @mitu Didnt help unfortunately
                                • Solid OneS
                                  Solid One
                                  Out of curiosity, what happens if you run it from terminal by plugging a usb keyboard and pressing F4?
                                  You could try it and post here all the error details that appears on screen. It'll help us figure out why it isn't working on your RPi4.
                                  • quicksilverQ
                                    quicksilver @Solid One
                                    @Solid-One It does work, just not with dispmanx scaling turned on.
                                    • Solid OneS
                                      Solid One
                                      So the problem is on dispmanx, right?
                                      Well, what about trying an approach similar to this one in SORR? AFAIK, both BennuGD and Doom Legacy were developed in SDL1, so maybe that should work (assuming that, somehow, SORR doesn't uses dispmanx).
                                      • tpo1990T
                                        tpo1990
                                        From what I have tried lately on my PI4, is that it does not launch from emulationstation by its runcommand file doom.sh with dispmanx. If I change the directory to /opt/retropie/ports/doom and launch doomlegacy binary from the terminal it starts up just fine.
                                        I'm not sure about how to solve the issue on the Pi4. Maybe someone else here could look into providing a solution. From this point it only works on older PI such as the Pi 3B.
                                        • quicksilverQ
                                          With dispmanx?
                                          tpo1990T 1 Reply Last reply Reply Quote 0
                                          • Solid OneS
                                            Solid One
                                            Out of curiosity, isn't dispmanx needed only by apps that needs X Server in order to run? RetroArch and other SDL1 / SDL2 apps doesn't require necessarily a X server to run, per example. However, there's still some apps that requires a X Server, such as FoFix (Frets on Fire).
                                            Probably I'm wrongly assuming that dispmanx is entirely related to X Server, but if my assumptions are right and dispmanx isn't required, then I guess it's possible to run DL on Pi4. A few years ago, DL ran through X Server, however they recently ported the entire app to SDL1 (unlike ReMooD, that is a DL fork based on a older version), so that should work in theory at least.
