Mario Kart 64 Sound Problem
Hey Guys I got an Pi2 B+ and want to know if meanwhile a solutun comes up to get the sound problem fixed..
My Problem is that the game doesn't run so well everytime when the soudn scrap the game is also a little bit hanging and stacking.
I also got a Pi3 and know with overclocking it handleable, but I want also to fix this just für MarioKart 64 on my Pi2B+, cause some friends are coming around in 1 hour and I don't have time to set up the Pi3.THanks for any help
@karimi nothing you can do to make it run favourably on the B+. Just not powerful enough. Pull out your PC if you want decent n64 emulation
so with the Pi3 it's also not well running?!
I would recommend the following videos
Runs like a dream on pi 3 even with HD Texture packs enabled
On a 2 I'm sure with an overclock, setting the glide plugin downscaling to 640x480 it will run fine.
Just look into overclocking especially v3d_freq and bumping up gpu_mem and setting your plugin settings correctly.
