    MSX SD Snatcher - Need help getting it running in BlueMSX
    msxbluemsxsnatcher
    2 Posts 2 Posters 941 Views
    • TPRT
      TPR
      Has anyone gotten MSX SD Snatcher to work? I seem to have two different version of the English Translation version each of them have different issues. I have either one of two problems:
      1. I'm told "Insert Sound Cartridge" and no matter what option I've chosen under "Cart Mapper" in the RetroArch options menu including all the Konami SCC options, nothing works.
      2. I get to a "Press 1 to Install or Press 0 to run game" screen, and when I press 0, then go to Disk Control and insert the next disk and press a key, I just get a "Wait...." screen that sits there forever.
      Any ideas? All my BIOS files are in the right place as I can load up everything else 100% fine.
      Thanks.
      • EfriimE
        Efriim
        I tried a lot.
        There is a SDSnatcher rom without SCC that will work.
