    Aimtrak Installation Issue
    aimtrakpythonoptional packag
    47 Posts 6 Posters 9.9k Views
      a1084426 @grant2258
      @grant2258 that file comes up blank or as a new file so must not get created when running with the log option.
      • EfriimE
        Efriim
        Could try again from start, maybe the python setup was missed?
        sudo apt install apt-transport-https python-dev python-pygame python-setuptools
        git clone https://github.com/gunpadawan/gunconf
        cd gunconf
        sudo python setup.py install
        sudo cp utils/aimtrak.rules /etc/udev/rules.d/99-aimtrak.rules
        sudo udevadm control --reload-rules
        sudo cp utils/gunconf.sh /home/pi/RetroPie/retropiemenu/
        I apologize I missed that step when I posted earlier, I thought it was a good reference to the hub I guess.
          a1084426 @Efriim
          @Efriim yeah ive done it 3 times now, I also increased the logging level to critical incase, but still nothing in the logs at all. It's almost as if the script itself doesn't have permissions to read the config from the usb device is my guess. I have Unix and python gurus at work i'm going to work thru it with as other than that the aimtrak gun works ok, justs needs calibration as some games like Lethal enforcers require you to shoot off screen to reload and this doesn't work to well without setting calibration
          It's also worth nothing I have firmware 9.2 on the gun device as well. I doesn't have an issue reading and calibrating on windows, so I assume its an issue with Python and some sort of access on the Raspberry as that's Debian
          • EfriimE
            Efriim @a1084426
            @a1084426
            Okay, thanks for being understanding, I've been away and did not read many the updates.
            I have no aimtrak device, the script gunconf calibration works for me from a RetroPie 4.4 image. So it is probably not the usb device.
            I just got a 64gb sdcard so I'm starting new, and I'll try some things to see if I can understand your scenario better.
              a1084426 @Efriim
              @Efriim that's fine I'm a windows admin so Raspberry and Linux is a little foreign. I've got some commands to run on the install "sudo python setup.py install /home/pi/gunconf/test.log 2>&1" this will log everything to a file on the install so I can see if anything gets a denied or error and then go from there. I do see a permission denied on some folder but it scrolls off to quick so I cant see if that's an issue or not.
              I also updated to latest Raspberry OS and made sure it is using python 2.7.
              the script actually mostly works and detects the trigger pull fine, just then doesn't goto the next step to read the gun config
              • EfriimE
                Efriim @a1084426
                @a1084426
                What raspberry pi model, and which retropie image have you built up from?
                A 2 Replies Last reply Reply Quote 0
                  a1084426 @Efriim
                  @Efriim pi 3 b+ Debian - Stretch image, then everything on top, emulation station etc etc. I upgraded raspi config OS modules to the latest from the retropie setup menu. If you want specific version numbers I can get these when I get home and post. Retropie is 4.4.12 I think or updated last 3 weeks ago
                    a1084426 @Efriim
                    @Efriim I also tried a pre built Stretch image from arcade punks 32gb one and updated and same issue, thinking its either version related or permission issue somewhere. I could try use the default image with noobs on it, just install emulation station and retropie, no upgrades then run this script or the Easy Hax to install advance mame and try again
                    • EfriimE
                      Efriim @a1084426
                      @a1084426
                      Yeah, try this first python --version
                      running the sudo python setup.py install, required an internet connection or at least used it when the script was executed. I'm wondering now how to uninstall
                      did not work for me the command wasn't interpreted correctly and the install was ignored no log file created.
                      EDIT
                      I think I was able to uninstall by running
                      sudo pip uninstall pyusb pgu gunconf
                      and removing
                      sudo rm /etc/udev/rules.d/99-aimtrak.rules
                      you could give me a list of your installed python scripts by typing
                      pip list
                      also what is the shell environment you are using
                      echo $0
                      and
                      python --version
                      A 3 Replies Last reply Reply Quote 0
                        a1084426 @Efriim
                        @Efriim yeah the log didn't work either for me. I will try the above when I get back home and post. I also spoke to the Linux guys here about adding 0777 as the access on the rules fiel just incase it was a perms issue to the usb device
                          a1084426 @Efriim
                          @Efriim pip list
                          dnspython (1.15.0)
                          evdev (0.7.0)
                          gunconf (0.2.0rc2)
                          numpy (1.12.1)
                          pgu (0.18)
                          pip (9.0.1)
                          pycrypto (2.6.1)
                          pygame (1.9.3)
                          pygobject (3.22.0)
                          pyudev (0.21.0)
                          pyusb (1.0.2)
                          RPi.GPIO (0.5.11)
                          setuptools (33.1.1)
                          six (1.12.0)
                          running bash environment
                            a1084426 @Efriim
                            @Efriim python version 2.7.13
                            • EfriimE
                              Efriim @a1084426
                              @a1084426
                              Everything looks good except for evdev (0.7.0) and RPi.GPIO (0.5.11)
                              I have evdev (1.2.0) and RPi.GIPO (0.6.5)
                              We could try uninstalling them they are easy to reinstall
                              pip uninstall evdev
                              pip uninstall RPi.GPIO
                              sudo apt-get install --reinstall apt-transport-https python-dev python-pygame python-setuptools
                              cd
                              cd gunconf
                              evdev should be installed with the setup.py script, an internet connection may be required for it to download, or you could try simply the command below, to see if it will update.
                              pip install evdev
                                a1084426 @Efriim
                                @Efriim will try this when home. One issue I have atm with mame 2003 is with my Xarcade Tank stick and the lightgun install it sends the autoconfig haywire. so I have started to use advmame on all my arcade roms as this seems to play nicer with a light and 2 joysticks installed. Have you found mame 2003 with devices like lightguns is harder to config
                                • EfriimE
                                  Efriim @a1084426
                                  @a1084426
                                  No experience with light guns, the usual problems I encounter with Mame are finding the parent roms and Mame versions.
                                  There was another thread before this one, where the solution we discovered for off screen aimtrak reticle drifit was solved by changing the Mame setting for mouse/device/lightgun sensitivity from 100 to %50.
                                  I am %80 confident that the evdev being the correct version will solve the earlier problem with gunconf.
                                    a1084426 @Efriim
                                    @Efriim sorry same error. ive even re-imaged to noob install no other updates other than default retropie basic install
                                    python version
                                    2.7.13
                                    pip list
                                    automationhat (0.1.0)
                                    blinker (1.3)
                                    blinkt (0.1.2)
                                    buttonshim (0.0.2)
                                    Cap1xxx (0.1.3)
                                    chardet (2.3.0)
                                    click (6.6)
                                    colorama (0.3.7)
                                    cryptography (1.7.1)
                                    dnspython (1.15.0)
                                    drumhat (0.1.0)
                                    enum34 (1.1.6)
                                    envirophat (1.0.0)
                                    evdev (1.2.0)
                                    ExplorerHAT (0.4.2)
                                    Flask (0.12.1)
                                    fourletterphat (0.1.0)
                                    gpiozero (1.4.1)
                                    gunconf (0.2.0rc2)
                                    idna (2.2)
                                    ipaddress (1.0.17)
                                    itsdangerous (0.24)
                                    Jinja2 (2.8)
                                    keyring (10.1)
                                    keyrings.alt (1.3)
                                    MarkupSafe (0.23)
                                    mcpi (0.1.1)
                                    microdotphat (0.2.1)
                                    mote (0.0.4)
                                    motephat (0.0.2)
                                    numpy (1.12.1)
                                    oauthlib (2.0.1)
                                    pantilthat (0.0.7)
                                    pgu (0.18)
                                    phatbeat (0.1.1)
                                    pianohat (0.1.0)
                                    picamera (1.13)
                                    picraft (1.0)
                                    piglow (1.2.4)
                                    pigpio (1.38)
                                    Pillow (4.0.0)
                                    pip (9.0.1)
                                    pyasn1 (0.1.9)
                                    pycrypto (2.6.1)
                                    pygame (1.9.3)
                                    pygobject (3.22.0)
                                    pyinotify (0.9.6)
                                    PyJWT (1.4.2)
                                    pyOpenSSL (16.2.0)
                                    pyserial (3.2.1)
                                    pyudev (0.21.0)
                                    pyusb (1.0.2)
                                    pyxdg (0.25)
                                    rainbowhat (0.1.0)
                                    requests (2.12.4)
                                    requests-oauthlib (0.7.0)
                                    RPi.GPIO (0.6.5)
                                    RTIMULib (7.2.1)
                                    scrollphat (0.0.7)
                                    scrollphathd (1.2.1)
                                    SecretStorage (2.3.1)
                                    sense-emu (1.1)
                                    sense-hat (2.2.0)
                                    setuptools (33.1.1)
                                    simplejson (3.10.0)
                                    six (1.12.0)
                                    skywriter (0.0.7)
                                    sn3218 (1.2.7)
                                    spidev (3.3)
                                    touchphat (0.0.1)
                                    twython (3.4.0)
                                    unicornhathd (0.0.4)
                                    urllib3 (1.19.1)
                                    Werkzeug (0.11.15)
                                    wheel (0.29.0)
                                      a1084426
                                      the aimtrak firmware is 9.2 as well on the device if that helps too that's the only other thing I can think of
                                      • EfriimE
                                        Efriim @a1084426
                                        @a1084426
                                        It's my fault for believing the resolution must exist in the guncon installation.
                                        Perhaps then using the windows aimtrak utility to change the device mode and parameters. I'm at a loss. Either mouse mode and the device ids and firmware you have now, should all be okay.
                                        The rpi model is rpi zero? Why not have installed the retropie image found on the website here?
                                        I'll read about udev as I forgot my last question.
                                        The gunconf script closes after which function?
                                          a1084426 @Efriim
                                          @Efriim Raspberry pi 3 b+ with new noobs based raspberry pi 3 image, then a default Retropie image installed on it, from the main retropie uk website. So it's as vanilla as possible and as default as possible.
                                          The gunconf never closes it just sits there trying to read the gun config. The Exit button is highlighted and if you execute that, it then drops out to terminal mode.
                                          if you have a particular image I can try that as well as I have a few spare microsd cards
                                          • EfriimE
                                            Efriim @a1084426
                                            @a1084426
                                            I don't have an image to suggest than the retropie one. It is information for a better frame of reference.
                                            Do you have any dtparams or dtoverlays enabled in /boot/config.txt?
                                            gunconf/utils/gunconf_w_logs.sh
                                            That is the guncon script with logs.
                                            I think it will create a file ~/.gunconf.log
                                            Have you been able to read this log previously, it may have info for what is happening?
