    [SOFT] ARRM : Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie
    gamelistscrapersoftware
    250 Posts 24 Posters 160.0k Views
    • nexusone13N
      nexusone13 @ExarKunIv
      @ExarKunIv Hi, could you send me your mail @ nexusone13@gmail.com so I coud send you a test version with the 'screen title' option, please
      ARRM (Roms Manager, Scraper for Recalbox, Batocera, Retropie, ES...) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
      Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=start-en
      Discord: https://discord.gg/p7QsBTS
      • nexusone13N
        nexusone13
        Hi @mitu ,
        Could you tell me what are the right paths, on retropie, for systems overlays and games overlays please. Thank you :)
          mitu Global Moderator @nexusone13
          @nexusone13 RetroPie doesn't come with overlays and doesn't have any special path reserved for it.
          I think you can use the RetroArch defaults - $HOME/.config/retroarch/overlay for storing the images, $HOME/.config/retroarch/config/<CORE>/<GAME>.cfg for game overlay config.
          You can take a look at how TheBezelProject does it (see for Atari 2600) and use their convention and approach.
          nexusone13N 2 Replies Last reply Reply Quote 1
          • nexusone13N
            nexusone13 @mitu
            @mitu thanks mitu for your quick reply :)
            • nexusone13N
              nexusone13 @mitu
              For example, if I have this file for Atari 7800 in this directory :
              /opt/retropie/configs/all/retroarch/config/prosystem/ Activision Decathlon, The (USA).cfg
              containing this line :
              input_overlay = "/opt/retropie/configs/all/retroarch/overlay/atari5200/16-9/Activision Decathlon, The (USA).cfg"
              And this 2 files in this directory :
              /opt/retropie/configs/all/retroarch/overlay/atari5200/16-9/Activision Decathlon, The (USA).png
              It should be okay ?
              thx
                @nexusone13 This looks fine, though I'd say try to use the same system name everywhere (i.e. atari7800 instead of prosystem). There might be differences between ES in RetroPie to what is configured in Recalbox/Batocera w.r.t. system names - you can find RetroPie's list here.
                nexusone13N 1 Reply Last reply Reply Quote 2
                • nexusone13N
                  nexusone13 @mitu
                  @mitu Ok I thought the <CORE> you mentioned here: $HOME/.config/retroarch/config/<CORE>/<GAME>.cfg refered to the retroarch core used for a system.
                  So <CORE> can be the retropie ID of the system (atari7800, snes, genesis, neogeo...) ? that's right ?
                  Thanks for the Retropie systems ID list, it will be useful :)
                    @nexusone13 said in [SOFT] ARRM : Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie:
                    You're right - yes, that's correct.
                    But be aware that the Libretro core name might be spelled differently. For instance lr-fbalpha is FB Alpha, the lr-prosystem core name is ProSystem (see here). I think the core info files (see the previous reference) are the definitive info source.
                    nexusone13N 1 Reply Last reply Reply Quote 1
                    • nexusone13N
                      nexusone13 @mitu
                      @mitu Hi , is there a way to have access via a 'net use command' from Windows to the '/opt/retropie' directory ? As we can do with \\retropie\roms ? thanks :) .
                      nexusone13N 1 Reply Last reply Reply Quote 0
                      • nexusone13N
                        nexusone13 @nexusone13
                        @nexusone13 I answer to myself : it's already reachable via \retropie . sorry :)
                          @nexusone13 Not exactly, it's just the configs folder that's available (exported), not the whole /opt/retropie.
                          • nexusone13N
                            nexusone13 @mitu
                            @mitu yes you're right, But I just need to have access to 'configs', so I can upload overlays generated by arrm.
                            • nexusone13N
                              nexusone13
                              Hi All
                              New version available : 1.7.5.2 (05/14/2019)
                              • Typing on a letter in the database (if sorted in alphabetical order), positions the index on the first name of game found starting with this letter (request from Zing forum Recalbox)
                              • Following the deletion of Rom, the index is positioned on the next element and does not come back to the beginning of the list (request from Zing forum Recalbox)
                              • System Sorting / The sorting of the es_systems.cfg is now possible on Retropie.
                              • Added a 'retropie' checkbox to launch the 'Stop and Reboot EmulationStation' scripts, to manage the specificities of overlays Retropie, and the SystemSorter specified to Retropie (request of morenr1 on the retropie forum)
                              • Can retrieve and create overlays configuration files for Recalbox, Batocera and Retropie
                              • Added a 'filter duplicate games' button on the Game name or on the file name which allows to filter the Roms whose name of the game or the file name (without extension) appears on other Roms. Example for ARRM: 1943 and 1943kai will be listed as duplicated because 1943 appears in 1943kai (thanks to Zing for testing)
                              • Added a 'Screen Title' checkbox to get the game's Screen Title instead of the screenshot. If checked, it can be used as a Screenshot or in the Mix. (request of ExarKunIv on Retropie forum)
                              • Add a "Europe Media" checkbox to retrieve Europe's special media if present. (Lucinda's request on recalbox forum)
                              • Added an 'SS Media' checkbox to force SS media recovery (specifically created by Screenscraper)
                              • Added a checkbox 'add country' that adds the country, at the end of the game name, if this information is present in the name of the rom file.
                                  If the MD5 of the game is filled in, ARRM can retrieve on screenscraper the information of the Country of Rom, during a scrap or during a 'Verif name via MD5' (API V2 only)). With the MD5 the country information will be more complete.
                              • Tag Marquee and Video are now written in the gamelist.xml, in order to use these features in Batocera v5.21 and Retropie.
                              • Textbox to indicate a path for the videos (request of morenr1 forum retropie)
                              • If the mode '4 images' is not selected, only the tags 'image', 'video' and 'marquee' are now saved (previously boxart, screenshot, marquee, mix, cartridge were saved in the gamelist.xml) (request from kevinnash forum Recalbox)
                              • sound played (Back to the Future locomotive) at the end of a scrap. The sound can be activated via a checkbox 'end scrap sound' in the tab 'General options' (request of Kevinnash forum Recalbox).
                              • Line breaks and tabs are taken into account in the textbox 'description'. (bug brought back by Zing)
                              • Backup paths for overlay images, overlay configuration files and input_overlay 'can be set via a config file
                              • Fixed inconsistencies in media search (by country) using API v2
                              • Change the path to recover the original es_systems.cfg file on Batocera v5.21
                              • Fixed a bug when validating a nonexistent screenscraper account
                              • Added additional information about ScreenScraper user account (screenscraper login module)
                              • Remove redundant 'add disk / tape / side' button with 'Check Roms' which already applies the following checkboxes: 'Clean Name', 'Add Disk', 'Keep Rom Name', 'Add Country'
                              • Fixed bug on auto-assignment of template with 'Recompose image'
                              • Fixed various bugs
                              • Adding an Amstrad GX4000 template
                              ARRM Wiki (with some practical cases) : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=start-en
                              Download Link : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager use 'Mirror Link1' if you get an 'Invalid Token' error message.
                              nexusone13N 1 Reply Last reply Reply Quote 4
                              • nexusone13N
                                For those who have difficulty launching the application, here is a workaround. Take this file (registry key) http://dl.free.fr/nHWkEIygo
                                Unzip it and register the .reg file, then launch the application.
                                The application has a trouble when creating certain registry keys. I will work on it very quickly and publish a bugfree version.
                                Only occurs with new users
                                • nexusone13N
                                  Bug fixed. Online application updated
                                  • nexusone13N
                                    nexusone13
                                    Hi All
                                    New version available : 1.7.5.3 (05/17/2019)
                                    • Fixed the bug that prevented the v 1.7.5.2 application from getting started with new users.
                                    • Added a splashScreen at launch.
                                    • ExarKunIvE
                                      ExarKunIv
                                      first i have to say now that i have used your program a bit, i love it.
                                      it is my go to for scraping now.
                                      the thing is i cant for the life of me get the over lays to work.
                                      i check the box and i see that it downloads.
                                      i then copy the folders that it makes to the correct places. and nothing.
                                      not sure if im doing it wrong or what
                                      • nexusone13N
                                        @ExarKunIv Thanks for your comments :)
                                        Did you follow the Wiki ?
                                        • http://jujuvincebros.fr/wiki/arrm/doku.php?id=bezels_en#retropy_and_overlays
                                          and
                                        • http://jujuvincebros.fr/wiki/arrm/doku.php?id=bezels_en#creation_of_system_overlays_and_games_with_arrm_for_batocera_recalbox_and_retropie
                                        Be careful in the wiki about the change to be made manually about the core name
                                        Wiki excerpt:
                                        Note : For Retropie, consider changing the name of the 'system' directory to the name of the 'core' of the system. example: \\retropie\configs\all\retroarch\config\megadrive should be changed to \\retropie\configs\all\retroarch\config\Genesis Plus GX
                                        You can know the name of the 'Core' of a system by opening with a text editor the file (for megadrive) '\\retropie\configs\megadrive\content_history.lpl' which indicates the “core_name” used
                                        • nexusone13N
                                          nexusone13
                                          Hi All
                                          1.7.6.5 (06/10/2019)
                                          • Added translation of the interface in Chinese (thank you Lyon00)
                                          1.7.6.3 (06/10/2019)
                                          • The logs are centralized in a subdirectory (logs_arrm) of the selected system.
                                          • When 'Keep rom name' is checked, 'Add disk' & 'clean name' are disabled
                                          • Database update: rom / core arcade compatibility (BestArcade4Recalbox-19-05-09).
                                          • Add in the tools tab of a textbox to modify the compression parameters of pngequant (request of Ismaily T. M. on the JujuVinceBros facebook page)
                                          • Added in the tools tab a button 'Update Best Arcade Core' to update the database with the best core arcade based games. Uses the files 'fba_libretro.csv', 'mame2003.csv', 'mame2010.csv' from BestArcade4Recalbox-19-05-09 list: https://docs.google.com/spreadsheets/d/1F5tBguhRxpj1AQcnDWF6AVSx4av_Gm3cDQedQB7IECk/edit?usp=sharing. These files are located in '%appdata%\nexouille soft\arrm\database'. The 'Update Core' button uses this database.
                                          1.7.6.1
                                          • When adding disk taking into account of [Part x of x] in the file name
                                          • When adding disk taking into account references memory sizes (16k) (48k) (128k). I use it for my collection of Roms Zx Spectrum which proposed 3 sizes different memories and therefore slightly different Roms.
                                          • Taking into account the video during a recompose image if the video file is present (Jay's request)
                                          • Ability to add a video manually to a Rom via the 'Video' button in the game card (Jay's request)
                                          • Ability to stop the various treatments applied to selected Roms.
                                          • Ability to modify the timeout value on web requests (via the 'Tools' tab). Increase the value when scrap server is overloaded.
                                          • Use the 32bits or 64bits version of pngequant (compressor PNG) depending on your environment.
                                          • When recovering Video only, '4 images' mode does not need to be activated.
                                          • Ability to recover the 'cartridge' as the default image.
                                          • When launching a scrap with overlay, the previous file "missing_overlays% SYSTEM% .txt" is saved with the current date.
                                          • Added the SNES CD template
                                          1.7.5.4 (05/18/2019)
                                          • Fixed a bug that crashed the application when duplicate search returned too many items.
                                          • Fixed bug when searching with keywords and with filters
                                          • Changed path for systems overlay path for recalbox in 'overlays_path.txt' file : /recalbox/share/system/configs/retroarch/overlays changed to /recalbox/share/system/.config/retroarch/overlays
                                            polpettedorso
                                            Hi!
                                            Yesterday i've downloaded and played with arrm. I did almost what i wanted, but i couldn' t find the option to scrape the wheel. How is this possibile?
