    [SOFT] ARRM : Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie
    gamelistscrapersoftware
    250 Posts 24 Posters 160.0k Views
    • nexusone13N
      nexusone13 @nexusone13
      Hi everyone,
      A new version of ARRM is available:
      1.9.2.0 (09/22/2022)
      • Added: Multi-thread scraping on Screenscraper is now possible with ARRM (Max 15 threads). See wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-en#multi-threaded_scraper_with_arrm_on_screenscraper
      • Added: 1920×1080 resolution available : you will find in the ARRM installation directory, two executables (Arrm_1080.exe and Arrm_32bits_1080.exe)
      • Modification: The 'Delete Rom' button also deletes associated media (request for cdaters)
      • Modification: In Boxart, Boxback and Cartridge templates are compatible with profile mode (perspective view) (request for cdaters)
      • Fixed: 'Research' tab combobox could have duplicate entries (reported by Nordicpower)
      • Fixed: Platform scraping on Launchbox caused a bug (reported by Balrog57)
      • Fixed: Multiple scrape on Launchbox no longer worked (reported by Nordicpower)
      • Fixed: The 'Genre' combobox was no longer powered (reported by Nordicpower)
      • Fixed: When 'Speed up' was not checked, some images found locally were not taken into account
      • Fixed: For Hyperspin export the following tags have been corrected: <dev> becomes <developer> , <player> becomes <players>
      • Fixed: When using 'Move to Folder', the content of some tags could be wrong
      • Fixed: Various bugs
      changelog from previous version 1.9.1.8 (08/29/2022)
      • Added: Added scrape engine on specialized GameTDB only on 3DS, DS, SWITCH, Wii and WiiU (search on title + platform). Returns Boxart (2d or 3d), BoxBack and Cartridge/CD. See wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-gametdb-en
      • Added: Added scrape engine on MobyGames (search on title + platform). Returns Screenshot (choose from 4 random), Titleshot, Boxart 2D, Boxback, Cartridge 2D, Wheel/logo(rarely) . See Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-mobygames-en
      • Added: 'ArcadeItalia' checkbox in the 'Arcade' tab associated with the 'Filter Arcade Clone' button, allows you to also check in ArcadeItalia if the selected rom is a clone, and indicates it in the 'temporary_rom' field
      • Added: When loading EBOOT.bin file for PS3 in the database, the name of the PS3 game is retrieved if the file path contains PS3_GAME\USRDIR
      • Added: In the tools tab you can now indicate the names of systems that correspond to Arcade, PC/DOS, ScummVM, Daphne/Singe. (used by ARRM for processing specific to these systems)
      • Added: Template fanart screenshot 720 which displays a Fanart in priority if not a screenshot. (asks Bob Morane)
      • Modification: The search for the long name of a rom is performed on new roms added when loading a system (search for Arcade/DOS/PC/Scummvm/Daphne/Singe systems.
      • Modification: The 'Rename with DAT' button also allows to find the long name of a game from its short name for Daphne/Singe/ScummmVM/Arcade/DOS/PC systems
      • Modification: If the 'No image, only texts' box of the 'Image options' tab is activated, it is possible to assign images in the MixMe module without recreating the Mix image. (request from Nordicpower) See wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=mixme_en#edit_add_images_and_keep_your_existing_mix_image
      • Modification: On Batocera, when 'PAD 2 KeY' is checked, and the system is in folder mode, the padto.keys file is copied into the game directory (request from Nordicpower)
      • Modification concerning the generation of HTML pages: see wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=html_generator-en
      • Fixed: When scraping on Screencraper if Fanart media was selected for TAGs other than Fanart, no image appears. (reported Balrog57)
      • Fixed: On MobyGames, sometimes a field could be too long and generated a warning message.
      • Fixed: Crash in 64-bit mode when unzipping 7zip file (reported Balrog57)
      • Fixed: On MobyGames, some fetched media had no extension or were size 0. (reported by Bob Morane)
      • Fixed: Interception of SQL crashes related to searches on GameTDB, SteamDB, LaunchBox
      Donwload links:
      Full version via arrm_setup.exe (remember to uninstall the previous version): http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
      Full version without using arrm_setup.exe. (Allows you to install or update the application by copying files): http://jujuvincebros.fr/telechargements2/category/12-arrm-executable-only
      Patch page and Beta : http://jujuvincebros.fr/telechargements2/category/11-arrm-update-correctif
      Changelog : http://jujuvincebros.fr/wiki/arrm/doku.php?id=changelog-en
      ARRM WIKI : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=Start-en
      Videos tutorial playlist : www.youtube.com/playlist?list=PLwA4JmSgv-PtLlzwPMOad5Ti96UfsbSzK
      Discord : https://discord.gg/p7QsBTS
      Twitter : https://twitter.com/ARRM_sofware
      Facebook : https://www.facebook.com/ARRMbyNexusone13
      Donations:
      Utip : https://www.utip.io/jujuvincebros/arrmdonation
      Buymeacoffee : https://www.buymeacoffee.com/ARRM
      Patreon : https://www.patreon.com/arrm
      ARRM (Roms Manager, Scraper for Recalbox, Batocera, Retropie, ES...) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
      Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=start-en
      Discord: https://discord.gg/p7QsBTS
      Z 1 Reply Last reply Reply Quote 4
      • Z
        ZzackK @nexusone13
        @nexusone13 thx :)
        • Z
          ZzackK
          Mix images have name like: Pole Position (USA) (Proto)-mix.png
          Is possible set name without "-mix"
          Image like rom file dont help in this case.
          EmuDeck using Emulation Station Desktop Edition and folders for images and gamelist are in another places.
          • FollyF Folly referenced this topic on
          • Z
            ZzackK
            Game lists xml in Emudeck dont support links. Images must have the same name like roms.
            nexusone13N 1 Reply Last reply Reply Quote 0
            • nexusone13N
              nexusone13 @ZzackK
              @ZzackK ARRM uses these suffixes for internal processing. However, you can remove them by hand by following this tutorial: http://jujuvincebros.fr/wiki/arrm/doku.php?id=howto_remove_suffix_en
              • Z
                ZzackK @nexusone13
                @nexusone13 thx works but is not comfortable :)
                • Z
                  ZzackK
                  Is possible set rom file name like in gamelist?
                  • W WhiteT982 referenced this topic on
                  • nexusone13N
                    nexusone13 @ZzackK
                    Hi everyone,
                    1.9.2.2 (11/09/2022)
                    • Added: Added Extra1 and Wheelround donwload counter
                    • Added: Button 'Reset Media Bar' in the tab 'Tools' allows to reset the coordinates of the Media Bar if it is no longer accessible.
                    • Added: Checkbox "Article at end" dissociated from the "Clean name" button
                    • Added: Checkbox 'Ignore empty video' in 'Image Options' tab allows to ignore empty videos recovered on screenscraper which displays 'This game is not playable' (mainly on ps2)
                    • Added: Zoom of the image possible by passing the mouse over the thumbnails when scraping with the engines offering a choice of game.
                    • Fixed : Various bugs
                    • Fixed: Browse button for 'Romlist Attractmod folder' was not active
                    • Fixed: In multithreaded scrape, round wheels were not retrieved
                    • Fixed: In some conditions, on different scrape engines, boxart files didn't have a .jpg/.png extension
                    • Fixed: Media Bar was inaccessible after clicking the window minimize icon.
                    • Fixed: Since version 1.9.2.0 regions were not correctly retrieved
                    • Fixed: The 'Check Roms' button added a ./ in front of the game name when the 'Add country' option was activated
                    • Modification: Improved search on MobyGames
                    • Modification: In multithreaded scrape, it is possible to choose RoundWheel as the default image.
                    • Modification: It is possible to deactivate the image/marquee/thumbnail tags when saving the gamelist. (The entirety of the tags will always be kept in gamelist_ARRM.xml)
                    • Modification: Optimization of the scraping on screenscraper.
                    • Modification: The button 'Name via DAT' allows to find the names of PS3/Switch/WiiU/Wii/Gamecube/3DS/DS games, if the file name contains the title ID of the game
                    • Modification: The choice of the TAG image is now done via a combobox (more choices possible)
                    • Modification: When loading a system, the names of PS3/Switch/WiiU/Wii/Gamecube/3DS/DS games as well as the language/country are retrieved if the path or filename contains the title ID of the game
                    Donwload links:
                    Donations:
                    nexusone13N 1 Reply Last reply Reply Quote 3
                    • nexusone13N
                      Hi everyone,
                      1.9.2.4 (11/29/2022)
                      • Added: It is possible to modify (or empty) the suffixes of the media (-image, -boxart etc...) via the 'Folders' tab. Warning: if you use a single folder for your media, specify different suffixes so as not to overwrite your images.
                      • Added: In the scrape windows, if the user does not act (mouse movement/click), the game is ignored after a time defined in the 'Scrape Options' tab. Skipped games are indicated in the file %appdata%\Nexouille Soft\Arrm\temp_skipped_arrm_%SYSTEM%_%SCRAPE_ENGINE%.txt
                      • Added: Various translations
                      • Added: Some logos and wheels
                      • Modification: Now Mix images have by default the suffix -image in the image TAG (formerly -mix)
                      • Modification: Search on Mobygames could return Cartridge Back instead of Cartridge Front
                      • Modification: Stopping a scrape is now done via a unique STOP button
                      • Fixed: Crash on 1.9.2.3 when multithreaded scraping on screenscraper
                      • Fixed: Since version 1.9.2.2, there could be crashes in the MixMe module if the choice of the TAG image was different from MIX
                      • Fixed: On Mobygames, sometimes images could be size 0
                      • Fixed: On GameTDB, sometimes Box3Ds were not retrieved
                      • Fixed: Display bug when clicking on scrape engine buttons
                      • Fixed: Rom deletion problem in some cases
                      • Fixed: Default images not displayed
                      Donwload links:
                      Patch page and Beta : http://jujuvincebros.fr/telechargements2/category/11-arrm-update-correctifChangelog : http://jujuvincebros.fr/wiki/arrm/doku.php?id=changelog-en
                      ARRM WIKI : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=Start-enVideos
                      Donations:
                      nexusone13N 1 Reply Last reply Reply Quote 2
                      • nexusone13N
                        Hi everyone,
                        2.0.0.1 (03/21/2023)
                        • Modification: Redesigned application. Screenshots : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:screenshots_en_relooked
                        • Added "Header (SteamDB") checkbox in the "Images Options" tab, allows to retrieve the Steam game header and stores it in the wheels directory with the -header suffix. It is not assigned to any TAG in the gamelist.xml (request from bob morane)
                        • Added romsize / romsize in screenscraper API call
                        • "kidgame" tag taken into account when creating the gamelist for Batocera/Retrobat/Retropie
                        • Addition of NextPixel Supervision and Megaduck templates available in the templates donwload module (Update tab)
                        • Various bug fixes
                        Donwload links:
                        Download link: http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
                        Donwload link for ARRM without installer : http://jujuvincebros.fr/telechargements2/category/12-arrm-executable-only
                        Download link for Beta: http://jujuvincebros.fr/telechargements2/category/11-arrm-update-correctif
                        ARRM WIKI : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:start-en
                        nexusone13N 1 Reply Last reply Reply Quote 4
                        • nexusone13N
                          Hi everyone,
                          2.0.0.2 (03/31/2023)
                          • Modification: Redesigned application (screenshots : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:screenshots_en_relooked )
                          • Modification: Searches on Launchbox are also done on alternative names
                          • Modification: In 'Selected systems' Tab, The "Retrieve Wheels Systems" button only retrieves the wheels + wheels-carbon of the systems checked in the list of systems.
                          • Fixed: A crash could occur when scraping if the system was not entered in the list of systems recognized by the scraping engine.
                          • Fixed: scrape on Mobygames not working anymore
                          • Fixed: On GOG the descriptions could be wrong
                          • Fixed: On GOG the promotional videos of the site are no longer retrieved
                          • Fixed: In single-threaded scrape on Screenscraper, the titleshot was saved with the suffix of the screenshot, thus overwriting the latter. (thanks foclabroc)
                          • Added: In the 'Updates' tab, checkbox 'Check if a Beta is available', allows you to check the presence of the Beta when launching the program.
                          • Added: In the Tools tab, the button 'Check if the systems exist in the list of scrape engine systems', allows you to generate the list of systems not found in the list of scrape engine systems. If a system does not appear in a scrape engine's list of systems, the scrape may not find anything. Warning: To screenscraper, it is imperative that the system is in the list. See Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:check_systems_in_scrape_engine_en_relooked
                          • Added: when scraping on screenscraper, it is now possible to scrape a game on several different platforms. See Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:scraper-screenscraper-en_relooked#how_to_scrape_a_system_on_multiple_platforms (thanks Andea for the suggestion)
                          • Added: In the 'Selected systems' tab, The "Get Arcade Wheels" button retrieves the list of arcade wheels for the systems defined in the arcadesystemename_long.txt file
                          • Added taillerom (romsize) in screenscraper API call
                          Donwload links:
                          Changelog : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:changelog-en_relooked
                          ARRM WIKI : http://jujuvincebros.fr/wiki/arrm/doku.phpVideos
                          ExarKunIvE 1 Reply Last reply Reply Quote 5
                          • ExarKunIvE
                            ExarKunIv @nexusone13
                            @nexusone13 I love that you are still improving this.
                            I just redid my system. And using a new theme I want to see how some other scraps will look with it.
                            Can wait to play around with your updates
                            nexusone13N 1 Reply Last reply Reply Quote 1
                            • nexusone13N
                              nexusone13 @ExarKunIv
                              Hi everyone,
                              2.0.0.4 (05/04/2023)
                              • Added: It is possible to scrape arcade Roms on ArcadeItalia (ArcadeDB) (http://adb.arcadeitalia.net/)
                              • Added: In file mode, it is possible to indicate per system at what depth to search for rom files in folders (file mode) via the file %appdata%\Nexouille Soft\arrm\Database\folder_search_depth_per_system.txt modifiable via the 'Settings' tab, 'Configuration files' tab, 'Change folder search depth by system' button. See Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:file_or_folder_mode-en_relooked#roms_search_depth_in_folders_in_file_mode
                              • Modification: it is now possible to make ARRM portable. Read the wiki for the implementation: http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_fr:make_arrm_portable-fr_relooked
                              • Modification: The list of systems to be processed in Folder mode is now configurable via the 'Configuration files' tab of the 'Settings' tab . Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:file_or_folder_mode-en_relooked
                              • Modification: The checkboxes of the desired media tags in the gamelist of the 'Gamelist' tab are now memorized
                              • Fixed: When deleting unused media, '-header' images are no longer deleted
                              • Fixed: Using the 'Filter Arcade Clone' button with the 'ArcadeItalia' option checked could cause the application to crash
                              • nexusone13N
                                Hi everyone,
                                2.0.0.7 (06/10/2023)
                                • Added: 'Theme-Builder' folder in the 'Folders' tab in which will be stored media dedicated to the creator of themes / custom package. You will find there the Wheels created by the Wheel generator (see below), the Steam headers, custom marquee etc...
                                • Modification: Steam headers are now saved in the 'Theme-Builder' folder
                                • Addition: Simple Wheel generator: it can generate Wheels containing, at your choice: the title of the game, cleaned or not (suffix -wheeltitle), the Publisher (suffix -wheelpublisher), the Developer (suffix -wheeldeveloper), the genres (suffix -wheelgenre).
                                  These wheels are created in the 'theme-builder' directory
                                  For the last 3 you can limit the number of items to display. Text color can be solid (selectable via combobox) or randomly generated for each Wheel. See wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:creating_simple_wheel_en_relooked
                                • Modification: When scraping on Screenscraper the native extension of the images is kept (png/jpg...)
                                • Added: We can now assign to Thumbnail and Marquee the desired media for all Scrape engines
                                • Added: 'Assign media for other scrape engines' button in the 'Settings/General Options' tab. See wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:media-assignation-other_scrapers-en_relooked
                                • Added: In the 'Settings/Images Options' tab, the 'Marquee' and 'Thumbnail' checkboxes allow you to force the download of these media.
                                • Added: 'Thumbnail', 'Marquee', 'Bezel' directories are configurable in the 'Settings/Folders' tab.
                                • Added: In the templates, taking into account the <thumbnail> tag for Thumbnail and <marquee3> for Marquee
                                • Added: For Batocera and Retrobat the recovered bezels are copied into the chosen bezels directory and written in the gamelist in the <bezel> tag
                                • Added: Checkbox 'CRC32 before scraping' which calculates the crc32 hash of the file and writes it in the <hash> tag of the gamelist. This calculation is done before the scrape on any scrape engine if this option is checked
                                • Modification: Checkbox 'MD5 before scraping' calculates the MD5 before scraping on any scraping engine if this option is checked
                                • Added: In the 'Gamelist' tab, addition of the 'Bezel' checkbox to write or not the <bezel> tag in the gamelist
                                • Added: In the 'Replacements' module it is possible to use regular expressions (Regex) in the 'Replace' field. See wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:apply_replace_en_relooked#using_regex
                                • Added: in the 'Replacements' module it is possible to use the %%year_only%% variable to retrieve only the year of the game's release date (and not the long format of the type: 19911014T000000)
                                • Modification: The 'Compose image' button has been duplicated and moved to the level of the other scrape buttons for more convenience.
                                • Added: jpg images can be compressed now
                                • Added: Parameters of cjpeg (jpeg compressor) in tools tab / image encoder (by default: -quality 90)
                                • Added: In the mode: 'Missing media only', the creation of the Mix is only done if media has been found
                                • Added: A special example template (retro_gamesheet) generating files with extension '-gamesheet' which can contain text information. Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:gamesheet_en
                                • Added: template mix + video 'Recalbox V2 like (square)'
                                • Added: template gamesheet 'retro_gamesheet'
                                • Modification : The Bezel Project button allows you to choose between Themed or System Art bezels. Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:bezels_project_en_relooked
                                Donations : http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:donations-en_relooked
                                • ExarKunIvE ExarKunIv referenced this topic on
                                • nexusone13N
                                  Hi everyone,
                                  2.0.0.8 (07/05/2023)
                                  • Addition : added following fields in the database: ratio, rotation, bezel and extra1
                                  • Addition : added <rotation> tag used by Recalbox for TATE mode. This tag is retrieved only when scraping on Screenscraper. A 'Rotate Tag' button in the 'Selected Roms' panel allows you to configure ARRM so that it only updates this field and then launches the scrape on Screenscraper. See wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:grab_rotation_tag_en_relooked
                                  • Addition : added <ratio> tag
                                  • Addition : added <bezel> tag used by Retrobat (Batocera??) which points to the bezel of the game. A 'Bezel' folder is configurable in the 'Folders' tab
                                  • Addition : added, following Pajarorrojo's suggestion, of a small module that allows you to select your favorite systems, so as not to clutter the checkedlistbox with systems that don't interest you. See wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:favorite-system-en
                                  • Addition : added 'Max' checkbox next to the 'Video' checkbox in the 'image options' tab allows when scraping video on SteamDB, to recover the video in its maximum resolution, otherwise in 480. For better quality, do not compress the video (beware, the file may be large)
                                  • Addition : added Template mix_recalbox_mixrbv1 and mix_recalbox_mixrbv2
                                  • Addition : added WASM4 and Arduboy templates from RustyMG available via the 'Updates' tab, 'Download new Mix templates' button
                                  • Modification : Media directories are only created when the media is retrieved
                                  • Modification : When scraping on SteamDB, the Subtitles of the videos are in the same language as the ARRM interface.
                                  • Fixed : Multi-thread scrape on screenscraper could crash if 'Missing Media' option was checked and no game met this criterion
                                  • Fixed : Marquee and Thumbnail checkboxes were not remembered
                                  • Fixed : various bugs
                                    Madcore
                                    Hi. I tried this program to scrape my collection, and I found it really powerful and suits all my needs.
                                    The only thing I miss is being capable of use a system or platform variable on the folder paths for media download. I have my media separate from roms in another folder, to have everything nice and clean on pc where I have all my collection. I know this is not very orthodox to do when it come to use in Retropie or Recalbox, but in PC I like to had it that way, and being capable of using a variable on the folder path is faster than rebuild the xml with macros to have a new path.
                                    Is there a way to do that?
                                    • nexusone13N
                                      Hi everyone,
                                      2.0.0.9 (09/09/2023)
                                      • Fixed: The copy of the 'Manual' file was not done when adding a manual via the icon of the 'Rom Information' panel (thanks msrecko)
                                      • Fixed: On ArcadeDBItalia, screenshots had no dot before extension (ex 005png instead of 005.png) (thanks RGS)
                                      • Fixed: In the Mix'Me Module, the MIX is dissociated from the IMAGE tag (unless you have chosen MIX as the IMAGE tag in combobox located in the 'Images Options' tab)
                                      • Added: In the 'Scrape options' tab, 'Missing text only' checkbox allows during a scrape to update only checked missing text metadata. see wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:scrape_missing_text_en_relooked
                                      • Added: 'Select' tab in which the buttons allowing you to make rom selections are centralized: Roms with missing media, Rom with missing text, Rom with missing overlay, Rom with missing Pad2key
                                      • Added: 'Roms with missing media' button, allows you to highlight (select) games that do not have the media checked in the Settings / Images Options tab
                                      • Added: 'Roms with missing text' button, allows you to highlight (select) games that do not have the texts checked in the ROM information panel. Only these texts are checked: Game Name, Description, Rating, Year, Developer, Publisher, Players, Genre, Regions, Languages
                                      • Added: In the Mix'Me Module the extensions of the source media files are kept. (the .png is no longer forced)
                                      • Added: In the Mix'Me Module, you can now select a media for the IMAGE tag
                                      • Addition: in the 'Folder' tab, addition of the 'Mix' folder where the MIX images (from a template) are stored and suffix for the Mixes
                                      • Added: 'Mix' checkbox in 'Images Options' tab: If checked, when creating a MIX using a Mix template (MIX in the 'Image TAG choice' combobox), the Mix image will be copied to the 'image' folder with the suffix defined for 'image' and in the 'mix' folder with the suffix defined for 'Mix'. If unchecked, the Mix image will be copied only to the 'image' folder with the suffix defined for 'image'
                                      • Added: checkbox 'keep Gametitle (retroarch)': For users of the Retroarch frontend, allows you to configure ARRM to retrieve named media respecting the name of the game from .DAT files. Read the wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=arrm_relooked_en:keep_gametitle_retroarch_en_relooked
                                      • Correction: when using template (MIX in the 'Image TAG choice' combobox), the resulting image will have the suffix defined for Mix, and will be stored in the MIX folder
                                      • Correction: on 2.0.0.8 when launching the application you could have this error message 'file not found: cache_database.mdb'
                                      • Fixed: Fixed THUMBNAIL and MARQUEE tag affections on Launchbox.
                                      Download link: https://shorturl.at/bintv
                                      Donwload link for ARRM without installer : https://shorturl.at/osEN2
                                      Download link for Beta: https://shorturl.at/orsW0
                                      Changelog : https://shorturl.at/chS18
                                      Videos tutorial playlist : https://shorturl.at/gizDN
                                      • nexusone13N
                                        Hi everyone,
                                        2.0.1.0 (11/05/2023)
                                        • Added: Textbox 'Ignore these files' in the 'Parameters' tab, 'Configuration files' Tab : Whe n loading a system, the indicated files are ignored. Can be used to ignore Bios files. You can use wildcards (* ?)
                                        • Added: 'family' and 'mode' tag
                                        • Added checkbox 'Ignore title search for these systems: 3DS, DS, GameCube, PS3, SWITCH, Wii, WiiU'. (this helps avoid bad naming)
                                        • Added: Intercepting errors on invalid images
                                        • Added: export module to retroarch. Allows you to export Media, Playlists and Overlays to Retroarch directories. See wiki: https://shorturl.at/BDIT5
                                        • Added: Renaming of Artworks based on the game name / ROM file name. See wiki: https://shorturl.at/rSVY7
                                        • Added: Checkbox 'Keep one genre' in the Gamelist tab: If checked, when saving the gamelist.xml, only the first genre of the game is kept. Warning: Other genres will be lost when you reload the gamelist.xml in ARRM
                                        • Added: When exporting to 'Hyperslist' only the first genre of the game is kept.
                                        • Added: When creating M3Us, alternative ROMs can be ignored via the 'Ignore Alternative Roms in M3U' checkbox in the 'Scrape Options' tab. The alternative tags sought are defined in 'Alternative Roms Tags' of the 'Configuration Files' tab
                                        • Modification: Some special characters (c)(tm)(r) (~)² (cube)... are removed during the search to increase the chances of results.
                                        • Modification: database engine detection method
                                        • Modification: When searching for duplicates, the filter is retained. We can then make other filter queries on the selection of duplicates.
                                        • Fixed : when using 'deleted unused artworks/videos' feature, 'extra1' images are taken into account
                                        • Fixed : In 'missing media' mode, during a scrape with Screenscraper Multithread, the roundwheel was downloaded even if already present
                                        • Fixed: Possible crash on other scrape engines, if 'seconds before ignore' was too large. It is now limited to 98 max
                                        • Fixed : If an xml contained prohibited characters, a crash could occur after the alert message
                                        • Fixed : Some images could be size 0 after unsuccessful compression: restoration of the original uncompressed image
                                        • Fixed : The wheelround was not retrieved from HFSDB when the 'Missing Media' checkbox was checked
                                        • Fixed: Deactivation of the search validation button by Title/Description/File when the textbox is empty (removes the resulting crash)
                                        ARRM WIKI : https://shorturl.at/aiBLT
                                        Donations : https://shorturl.at/iAFJK
                                        W 1 Reply Last reply Reply Quote 4
                                        • W
                                          wtstreetglow1 @nexusone13
                                          @nexusone13
                                          Thank you so much for sharing this tool with everyone. It is so helpful to someone that already has all of the scraped media and was wanting to start fresh!!
                                          Thank you again!!
                                          • nexusone13N
                                            nexusone13
                                            Hi everyone,
                                            2.0.1.2 (24/12/2023)
                                            • Modification: When searching on launchbox, removed the : in the game title, replace with -
                                            • Fixed: Even if 'Keep one genre' was not checked in the 'Gamelist' tab, only one genre was saved in gamelist.xml (not in gamelist_arrm.xml which kept all genres)
                                            • Modification: From now on when scraping on Arcade Italia, the game titles returned will be the long titles (eg: Top Driving (version 1.1.)) instead of the short titles (Top Driving). Use 'Clean Name' to remove this extra information.
                                            • Modification: Retroarch export is compatible with the different Retroarch platforms (Windows, Android, Linux, Wii etc....)
                                            • Modification: In the Retroarch export module, addition of the choice of 'Retroarch Cores folder' so that the correct core is indicated in the playlists (.lpl). Wiki : https://shorturl.at/dlrJN
                                            • Fixed: When scraping with Missing Media checked, MIX enabled and no media checked, the MIX is now correctly generated.
                                            • Added: For renaming Arcade Rom titles via DAT files, it is possible to indicate which DAT file to base on. See wiki: https://shorturl.at/jDEKT
                                            • Added: It is possible to check the integrity of media (corrupt, unreadable, etc.) when loading a gamelist if the 'check if media exists' checkbox is checked, or via the 'Media exists?' button. from the 'Selected Roms' tab. If a media is corrupted, it is deleted as well as its reference in the database. See wiki : https://t.ly/4gOmm
                                            • Added: It is possible to export a gamelist in %nom_platform%_GAME.csv format which you can use to constitute your GAME.CSV present in distributions such as 'GameStick Lite' See wiki: https://shorturl.at/CDHT9
