    GPIO power state led
    8 Posts 3 Posters 3.9k Views
    • Drakaen391D
      Drakaen391
      Can't find the GPIO board, but how can I get a power LED to work?
      Before I used the serial TX pin in my RPi B
      However it doesn't seem to work on my RPi 3 as the LED stays lit... Am I missing something?
      RPi B & RPi 3B OC (Now Raspberry pi 4b 8gb)
      Retropie (Latest Stable)
      PiBox with Wind Tunnel Cooling System
      • caver01C
        caver01
        This works on my Pi3: I wired wire an external LED with a resistor (mine is part of a power button and has the appropriate resistor built-in) to pin 8 (UART TXD). Is that what you already did? It works for me. When I do a soft shutdown, the LED goes out.
        Also, when I short GPIO3 (pin5) to ground, the Pi powers up, and the LED comes on again and stays on while running.
        • Drakaen391D
          Drakaen391
          I will double check my pin placement (going from a PiB to Pi3, so I may have messed up the pins...
          • Drakaen391D
            Drakaen391
            found the problem... I had in my notes GPIO 8 = TX for LED (from when I built my Rpi B...
            So instead of Pin 8, I had it in GPIO 8 (Pin 24)
            I feel sheepish :p
            • Drakaen391D
              Drakaen391
              this is the chart I use alt text
                space invader
                Hi!
                Could you please decribe how to wire the led to function as described?
                One led's pin to GPIO pin 8 (GPIO14) and the other led's pin to?
                5V? 3.3V? Ground?
                Thanks in advance!
                Drakaen391D 1 Reply Last reply Reply Quote 0
                • Drakaen391D
                  Drakaen391 @space invader
                  @space-invader the second would go to ground... Its recommended to have a resistor between the LED and the ground to prevent shorts...
                    space invader
                    Ok, thanks. I was affraid to put it in the incorrect pin.
