    Need help with transferring games.
    help me please
    3 Posts 2 Posters 77 Views
    • I
      itsjustjere
      All the sites I've looked at say that to write the retropie games on your flash drive, you have to write'retropie' decapitalized. I did that, and my PC keeps changing it to 'Retropie'. I don't know how to fix it. Can someone help? Thanks.
        mitu Global Moderator @itsjustjere
        @itsjustjere Try renaming the folder ? If your RetroPie is connected to your network, there are other - easier - methods to transfer your games, you don't necessarily need an USB flash drive - https://retropie.org.uk/docs/Transferring-Roms/#samba-shares.
        • I
          itsjustjere @mitu
          @mitu okay. Thanks.
