    Stanadalone PPSSPP control issue
    1 Posts 1 Posters 743 Views
      Concat
      Has anyone encountered an issue where the standalone PPSSPP is constantly registering an "UP" input while in menu? It makes it impossible to change any settings or even exit the emulator because it always rapidly moves the selector to the top of the menu.
      I managed to reset the controls, but it still happens...
      I even rebuilt from source and it did nothing to fix it. If I delete the PPSSPP.ini file, where the configs are located, will it recreate it once I start the emulator? I have a feeling one of the settings I changed is causing the problem, but I don't know which one. I want to reset the config file to default and start over...
      RPi3
      3.8.1
      Happens with keyboard only, with PS3 controller, doesn't matter what I use or how many devices are plugged in.
