    Mixed controller problems with two usb zero delay. Start + select not working
    3 Posts 3 Posters 1.3k Views
      raulegido
      Hello everyone.
      I´m trying to finish my retropie cabinet.
      Problem is this.
      start and select are working on main menus but when i enter a game those buttons don´t work.
      I´m also having a strange behaviour regarding those controllers.
      For example, i enter one game and sometimes the main controller is the left one and others the right one, if i change the usb connectors i still get those mixed results.
      I´m using two dragonrise usb controllers (Usb zero delay) for each player.
      Does anybody know how can i solve this?
      thanks a lot in advance
        robthedude81
        Hi
        Did you get anywhere with this???
        I think i am having the same issue with the same equipment
        • rauzerR
          rauzer
          hi
          i did 2 cabinets out of this dragonrise usb controller (2 for each player).
          i had same misconfiguration problems in all lr-* emus : wrong assignment of buttons, not working buttons, 2 buttons assigned to the same phisical button.
          i notice that the config made in setup panel of emulation station is correct but it gaves a interface name with spaces in it (i will post log later). i don't know if this leads to errors o bugs.
          all controls in emulationstation are ok but not in lr-* emus.
          i managed to resolve this only the hard way: hardcode every control lines directly in config/all/retroarch.cfg without let it pick control config from original control file.
          this has done the job but don't let you use other controllers beside dragonrise because config is hardcoded.
