    Prboom - pWads not loading. Log file offers strange reasons for not running.
    prboomdoompwad
    27 Posts 3 Posters 3.6k Views
    • XD3lX
      XD3l @mitu
      @mitu When using the script above (a modification of your own), then no, I only have AV in it's own folder along with the DEH and CFG files.
      It is only when I use a script based on the Wiki example that I have problems.
      File lay out:
      /home/pi/RetroPie/roms/ports/doom/pwad/av/
      -av.wad
      -av.deh
      -doom2.wad (or doom2.wad link, which ever)
      -prboom.wad (or prboom.wad link, which ever)
      -prboom.cfg (with deh and wad links included)
      and with this I use this script:
      #!/bin/bash
      /opt/retropie/supplementary/runcommand/runcommand.sh 0 "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-prboom/prboom_libretro.so --config /opt/retropie/configs/ports/doom/retroarch.cfg /home/pi/RetroPie/roms/doom/pwad/av/doom2.wad" "lr-prboom"
      Which in turn produces this error:
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-prboom/prboom_libretro.so --config /opt/retropie/configs/ports/doom/retroarch.cfg /home/pi/RetroPie/roms/doom/pwad/av/doom2.wad --appendconfig /dev/shm/retroarch.cfg
      retro_load_game: invalid WAD header '(���З/'
      D_DoomDeinit:
      This non-sense at the end after WAD header always seems to changed but always consists of garbage.
      And again, all files are freshly downloaded, and my iwad checks out A OK with an MD5 checker.
        mitu Global Moderator @XD3l
        @XD3l Did you try updating from source the lr-prboom package ? I got the same 'Invalid WAD header' before updating from source.
        XD3lX 2 Replies Last reply Reply Quote 0
          backstander
          I think we're making it to complicated and lr-prboom is smarter than we realized and doesn't need us telling it every single parameter and seams to automatically add the files it needs...somehow. Also the Doom wiki probably needs to be updated to reflect this.
          Both of these launch scripts seams to work for me and I'm not mentioning the doom2.wad or the av.deh but they both are getting loaded automatically.
          #!/bin/bash
          /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-prboom/prboom_libretro.so --config /opt/retropie/configs/ports/doom/retroarch.cfg "/home/pi/RetroPie/roms/ports/doom/av/av.wad" --appendconfig /dev/shm/retroarch.cfg
          and launching through the runcommand
          #!/bin/bash
          "/opt/retropie/supplementary/runcommand/runcommand.sh" 0 _PORT_ "doom" "/home/pi/RetroPie/roms/ports/doom/av/av.wad" "lr-prboom"
          Using the scripts above somehow loads all the files needed:
          W_Init: Init WADfiles.
           adding /home/pi/RetroPie/roms/ports/doom/doom2.wad
           adding /home/pi/RetroPie/roms/ports/doom/prboom.wad
           adding /home/pi/RetroPie/roms/ports/doom/av/av.wad
           adding /home/pi/RetroPie/roms/ports/doom/av/av.deh
          Here's my Alien Vendetta directory:
          pi@retropie16:~ $ ls -l ~/RetroPie/roms/ports/doom/av
          drwxr-x--- 2 pi pi     4096 May 26 09:49 av
          -rw-r--r-- 1 pi pi     7403 Dec 24  2002 av.deh
          -rw-r--r-- 1 pi pi  1816944 Dec 24  2002 avmovfix.wad
          -rw-r--r-- 1 pi pi 23819412 Dec 24  2002 av.wad
          -rw-r--r-- 1 pi pi    58599 May 26 09:38 prbmsav0.dsg
          -rw-r--r-- 1 pi pi    58599 May 26 09:34 prbmsav1.dsg
          -rw-r--r-- 1 pi pi     9642 May 26 21:36 prboom.cfg
          Note: when you launch through the runcommand it make a sub-directory named av (or both scripts use it...I'm not exactly sure) shown below:
          pi@retropie16:~ $ ls -l ~/RetroPie/roms/ports/doom/av/av
          -rw-r--r-- 1 pi pi 58943 May 26 09:49 prbmsav0.dsg
          -rw-r--r-- 1 pi pi  9630 May 26 21:37 prboom.cfg
          I don't have any symbolic links to the doom2.wad anywhere:
          pi@retropie16:~ $ sudo find ~/ -name "doom2.wad"
            backstander
            I have a hunch that when we add the location to doom2.wad in the launch script that it might be loading up doom2.wada 2nd time thinking it is a PWAD and giving us the retro_load_game: invalid WAD header error.
            • XD3lX
              XD3l @mitu
              This post is deleted!
              • XD3lX
                XD3l @mitu
                @mitu said in Prboom - pWads not loading. Log file offers strange reasons for not running.:
                I had deleted PrBOOM and re-installed it from scratch in fact, but now I just did a full system update and what do you know, it works!!!!
                Again, thank the both of you for all of your time!!! I don't often receive help on this site.
                • XD3lX
                  XD3l
                  And oddly enough I am attempting to duplicate all of these steps on my Pi3 setup and I am back to where I began. Except now the WAD Header error has a lot more garbage at the end than ever before.
                  EDIT: This only reflects the Run Command method.
