    Retroarch panel project
    projectexcelcheck all games
    1 Posts 1 Posters 594 Views
      ppuspfc
      Hi everyone.
      I would like to present you my project. I called it Retroarch Panel. It is just on Portuguese by now, but you can check it by visiting:
      https://paulorobertoelias.com.br/2019-06-01-projeto-retroarch-panel/
      https://github.com/PRElias/retroarch-panel
      The ideia is to get all your games from the gamelist.xml files and show on a searchable grid and allowing you to export as an Excel file.
      Best regards to all of you
