    Remove sound effects from a theme?
    theme help
    4 Posts 3 Posters 665 Views
      Spectral
      I'm using a theme called comic book. It plays a sound effect related to the system whenever a game is launched. Is there an easy way to disable that? I tried just renaming/removing the audio files and while it works it does throw an error up about not being able to find it. I'd prefer something neater.
      Thanks in advance
      • E
        ericbsmith42
        Instead of renaming instead replace it with a 1 second empty sound clip?
          mitu Global Moderator @Spectral
          @Spectral Why not disable the audio in Emulationstation's menu ?
            Spectral
            Because I don't want to lose all navigation sounds, I just don't like these specific ones, I think they sound tacky. Plus they vary in audio quality and volume.
            Replacing them with a silent audio file is definitely an option if I can't find a way to stop it from trying to play them.
            Ideally a way to edit the theme so it doesn't try to play them at all.
