    Is it possible to control audio balance in retropie?
    alsa stereosound volumestereo
    2 Posts 1 Posters 436 Views
    • flagrant99F
      flagrant99
      I get sound out of HMDI fine and I know I can set volume level for both speakers, but I can't seem to figure out how to control left and right channel volume levels independently.
      default:CARD=ALSA
      bcm2835 ALSA, bcm2835 ALSA
      Default Audio Device
      amixer scontrols -D default
      Simple mixer control 'PCM',0
      amixer
      Capabilities: pvolume pvolume-joined pswitch pswitch-joined
      Playback channels: Mono
      Limits: Playback -10239 - 400
      Mono: Playback -2038 [77%] [-20.38dB] [on]
      If I understand correctly I should still have stereo playback. It's just that the Simple Mixer Control does not support left and right channels?
      amixer controls
      numid=3,iface=MIXER,name='PCM Playback Route'
      numid=2,iface=MIXER,name='PCM Playback Switch'
      numid=1,iface=MIXER,name='PCM Playback Volume'
      numid=5,iface=PCM,name='IEC958 Playback Con Mask'
      numid=4,iface=PCM,name='IEC958 Playback Default'
      • flagrant99F
        flagrant99
        Does anybody know hot to get a mixer control that supports stereo on retropie?
