    Trouble with Clone PS3 Controller with bluetooth
    ps3 clonesbluetooth 4.4
    22 Posts 4 Posters 2.9k Views
      PCKid @BuZz
      @BuZz redid it all. When I configure input it says it's a Shawan controller so I select the six axis controller and also configure for third party controllers. Now shows registered devices as, line one, Sony PLAYSTATION 3 Controller and below that Active Connection > ACL 01:66:84:B8:63:25 handle 11 state 1 lm 1 MA 1 lm MASTER. Can program the buttons via USB but when I disconnect even though red light one is solid the buttons don't work. I did the whole connect via USB, unplug and press PS3 button and replug in then it says unplug and it will work but it doesn't. Says successfully authenticated PS3 controller. But no luck.
        PCKid @PCKid
        @PCKid ok hold the horses. Just fiddled with the controller in Bluetooth ie disconnected and some of the buttons work on the controller just not all and messed up. EG analog sticks work up down left right but none of the others do. Redid buttons now all good thank the maker. Thanks for all your help. No idea why it has suddenly decided to work but it does.
