    is using 2 usb sticks for roms possible ?
    usb driveroms
    5 Posts 2 Posters 416 Views
      shayne66
      have all my roms on a usb stick, and all working great. although the stick is full.
      i have found a spare 32gb usb stick and was wondering if i add more roms (for a different emulator)
      is it possible to have them both connected at the same time to the pi ?
        mitu Global Moderator @shayne66
        @shayne66 Yes, it would be possible, but you'll have to set them up manually, since the automatic mount doesn't support it. While you won't be able to combine them as a single disk, you can mount a few systems from it (psx or other CD-rom based consoles).
          shayne66
          hmmmm, might be easier to buy a bigger usb stick and put all roms together.
          if i choose to go that way, can i just copy and paste my existing file folders from old and working usb onto my new usb stick ? just that all roms have been scraped already.
            @shayne66 I think it should be ok to copy the contents from one USB to another. Just don't forget to format it properly first.
              shayne66
              cheers for the info. i'll go with the easy option for now.
