    Drastic on pi 3 1.2 not booting roms
    drasticroms wont loadpi 3 b
    27 Posts 4 Posters 4.4k Views
      joe.info @Efriim
      @Efriim do I just change it to 16:9 ?
      • EfriimE
        Efriim @joe.info
        @joe-info
        I Think 720x480 (480p) or 1280x720 (720p). Either 16:9 or 4:3.
        • quicksilverQ
          quicksilver @Efriim
          @Efriim the version of drastic available through retropie-setup has a known issue of not clearing the framebuffer after you exit the emulator. Try the newer version.
          https://retropie.org.uk/forum/topic/21826/newer-version-of-drastic-compatible-with-raspberry-pi
            joe.info @quicksilver
            @quicksilver I got drastic updated to the 2.5 from the link. Here is the new shm log
            Parameters:
            Executing: pushd /opt/retropie/configs/nds/drastic; /opt/retropie/emulators/drastic/drastic "/home/pi/RetroPie/roms/nds/5602 - Okamiden (U)/Okamiden (U).nds"; popd
            /opt/retropie/configs/nds/drastic ~
            ALSA lib confmisc.c:767:(parse_card) cannot find card '0'
            ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
            ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
            ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
            ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
            ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
            ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
            ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM default
            drastic: pcm_params.c:2290: snd_pcm_hw_refine: Assertion `pcm && params' failed.
            Starting DraStic (version r2.5.0.4)
            Checking directory /opt/retropie/configs/nds/drastic/backup: It's there.
            Checking directory /opt/retropie/configs/nds/drastic/savestates: It's there.
            Checking directory /opt/retropie/configs/nds/drastic/config: It's there.
            Checking directory /opt/retropie/configs/nds/drastic/profiles: It's there.
            Checking directory /opt/retropie/configs/nds/drastic/unzip_cache: It's there.
            Checking directory /opt/retropie/configs/nds/drastic/system: It's there.
            Checking directory /opt/retropie/configs/nds/drastic/input_record: It's there.
            Checking directory /opt/retropie/configs/nds/drastic/cheats: It's there.
            Checking directory /opt/retropie/configs/nds/drastic/slot2: It's there.
            Checking directory /opt/retropie/configs/nds/drastic/scripts: It's there.
            Setting default configuration.
            SDL input: Setting default controls for Generic X-Box Pad
            Loading directory config file /opt/retropie/configs/nds/drastic/config/drastic.cf2
            Directory config file /opt/retropie/configs/nds/drastic/config/drastic.cf2 does not exist.
            Loading config file /opt/retropie/configs/nds/drastic/config/drastic.cfg
            Config file /opt/retropie/configs/nds/drastic/config/drastic.cfg does not exist.
            1 joystick(s) found.
            Got memory mapped buffer at 0x740ec000 (drastic_mapped_memory.dat)
            Using memory map offset 0
            Direct mapping main RAM to 2000000
            Direct mapping main RAM to 2400000
            Direct mapping main RAM to 2800000
            Direct mapping main RAM to 2c00000
            Initializing ARM9 bus-level memory map.
            Initializing ARM7 bus-level memory map.
            Initializing CP15.
            Initializing DMA.
            ***Failed to load system file nds_firmware.bin.
            video_3d render targets: 0xad3fcc0 0xad63d80 0xad87e40 0xadabf00
            ERROR: Audio device failed to open (No such file or directory)
            /opt/retropie/supplementary/runcommand/runcommand.sh: line 1012: 777 Aborted /opt/retropie/emulators/drastic/drastic "/home/pi/RetroPie/roms/nds/5602 - Okamiden (U)/Okamiden (U).nds"
              joe.info @joe.info
              @joe-info Parameters:
              Got memory mapped buffer at 0x740cf000 (drastic_mapped_memory.dat)
              Initializing CP15.
              Initializing DMA.
              /opt/retropie/supplementary/runcommand/runcommand.sh: line 1012: 758 Aborted /opt/retropie/emulators/drastic/drastic "/home/pi/RetroPie/roms/nds/5602 - Okamiden (U)/Okamiden (U).nds"
                joe.info @joe.info
                @joe-info Here's my latest error log. I took config files from a working set up. the main difference is that I have Pinn Lite installed on this one for the hdmi swap feature. Could that be affecting how the emulator behaves?
                Parameters:
                Initializing CP15.
                Initializing DMA.
                /opt/retropie/supplementary/runcommand/runcommand.sh: line 1012: 734 Aborted /opt/retropie/emulators/drastic/drastic "/home/pi/RetroPie/roms/nds/5602 - Okamiden (U)/Okamiden (U).nds"
                  joe.info @joe.info
                  @joe-info
                  Solved.
                  Dtparam audio on fixed the drastic boot issue
