    BeebEm and fun arcade control modifications
    28 Posts 9 Posters 4.9k Views
    • Z
      zerojay @Lord Vek
      @Lord-Vek The instructions for how to use the repository are in the readme in the repository, which is displayed when you go to it on Github.
      • Lord VekL
        Lord Vek
        You mean here:
        https://github.com/zerojay?
        The standalone beebem or the script inside the RetroPie-Extra-unstable/scriptmodules/emulators?
        • Lord VekL
          Lord Vek
          I made a try for the standalone beebem. I used the command sudo ./configure --prefix=$HOME/test --enable-econet
          There is some activity... Then I get this message:
          *** Could not run GTK+ test program, checking why...
          *** The test program failed to compile or link. See the file config.log for the
          *** exact error that occured. This usually means GTK+ is incorrectly installed.
          configure: error: mypkgname 0.1 needs GTK+ 2.2.0
          What should I do?
          • Z
            zerojay
            My repository is found at https://github.com/zerojay/RetroPie-Extra.
            • Lord VekL
              Lord Vek
              Thanks for the answer. I will try to install it tomorrow if I find the time.
              • Lord VekL
                Lord Vek
                Hello again!
                I am sorry to bother you, but I don't see the beebem in your link's repository. Help?
                • Z
                  zerojay @Lord Vek
                  @Lord-Vek said in BeebEm and fun arcade control modifications:
                  Hello again!
                  It looks like I moved it into the unstable repository (https://github.com/zerojay/RetroPie-Extra-unstable) as it wasn't working as hoped. More info in the repository's README. I haven't touched it in ages so I don't know what state it is in right now.
                  • Lord VekL
                    Lord Vek
                    Yes, that was my question at the beginning. I asked how can I install something from that repository. What commands should I use from the Retropie, to install beebem. Can you please help me, because I am a noob?
