    UNIQUE Headphone Jack Audio Problem
    audioheadphone jackraspberry pi 3b
    3 Posts 2 Posters 379 Views
      A Former User
      Hardware: RPi 3B
      Power Supply used: 5.25V
      RetroPie Version Used: Retropie 4.4
      USB Devices connected: Keyboard, Arcade Controller (x2
      Issue: Every time I plug in my headphones into the RPI, you can hear the splashscreen video (at the start) very well and clear. Afterwards, crazy disrtortion, lag and static. Can anyone please help!
      GoldManSex778G 1 Reply Last reply Reply Quote 0
      • GoldManSex778G
        GoldManSex778 @A Former User
        @TheBossT You described a similar problem over hdmi in another post, and also something about an added touch screen with script. Have you tried testing the audio with a vanilla installation?
        Try playing an mp3 or something with omx player through the terminal (command line).
        If you get bad audio with that then I can be bad/conflicted drivers, a bad installation, or maybe bad hardware.
          A Former User
          Yeah, I've tested on a vanilla installation. The audio just is the same all round. :(
