    TRS-80 - SDLTRS does not work
    sdltrstrs-80
    9 Posts 2 Posters 1.1k Views
    • SebiohazardS
      Sebiohazard
      Hello everyone :)
      I installed the SDLTRS emulator with the experimental modules placed a game in .dsk format in the folder rom & placed the files level1.rom & level2.rom & level3.rom in the folder BIOS of RetroPie (Linux Mint)
      When I run a game I have a black screen nothing happens ... someone to help me ?!
        mitu Global Moderator @Sebiohazard
        @Sebiohazard Can you post the contents of the log file - /dev/shm/runcommand.log - , taken after the failing game ?
        What's the game you're trying to run ?
        • SebiohazardS
          Sebiohazard
          @mitu hello thank you for your help :) here is the contents of the file
          trs-80
          sdltrs-model1
          /home/sebiohazard/RetroPie/roms/trs-80/Zaxxon.dsk
          /opt/retropie/emulators/sdltrs/sdltrs -model 1 -romfile /home/sebiohazard/RetroPie/BIOS/level2.rom -showled -diskdir /home/sebiohazard/RetroPie/roms/trs-80 -disk0 "/home/sebiohazard/RetroPie/roms/trs-80/Zaxxon.dsk"
          The game is Zaxxon thanks
            I can't reproduce the error. Once I copied the ROM file into the BIOS folder, the game opened up:
            Granted, I'm on a RPI, so not on x86, but I think the emulator is the same. Are you sure you have the right BIOS and ROM file(s) ?
            • SebiohazardS
              Sebiohazard
              @mitu thank you for your help no I'm not sure I have the right BIOS can you give me the MD5 for these files please ?!
                The checksums are:
                • ca74822ebc2803c6635a55116ecd9539 BIOS/level2.rom
                • adea17bceb23204cfa3103e78d19e554 roms/trs-80/ZAXXON.dsk
                • SebiohazardS
                  Sebiohazard
                  @mitu a big thank you it works it's fantastic I love the TRS-80 !!!
                  it's the MD5 of the game that was not good...
                  Do you know how to change the color of the screen (green) there is a menu with color codes but I do not know what is the code for the green ?
                    The code for green is 0x008010 (try with or without the leading 0x).
                    • SebiohazardS
                      Sebiohazard
                      @mitu Hi & thanks for your answer i found this site which gives all the color codes :)
