    Flipped Display on Pi2Scart (to use with a half-silvered mirror)
    mirrorflippi2scart
    11 Posts 4 Posters 1.5k Views
    • OneSwitchO
      OneSwitch
      I'm wondering if anyone has had any luck flipping the display using a CRT display, so that it appears the right-way around when reflected on glass (i.e. as is done with the original Space Invaders).
      I've managed to do this with an HDMI monitor, but when I use...
      display_hdmi_rotate
      result
      0 - no rotation
      1 - rotate 90 degrees clockwise
      2 - rotate 180 degrees clockwise
      3 - rotate 270 degrees clockwise
      0x10000 horizontal flip
      0x20000 vertical flip
      0x30000 both flipped
      ...the image rotates, but never flips.
      Any ideas appreciated. Would be great to get Space Invaders and the RetroPie front end all working when used with a mirror.
      I'm using a Raspsberry Pi 3B+ with RetroPie 4.4 and Pi2Scart.
      • OneSwitchO
        OneSwitch
        I know self-bumping is a bit rude. Would love to find out if anyone has had luck flipping/mirroring an upright RetroPie Raspberry Pi 3B+ image using Pi2Scart. This would be so nice for anyone with a broken Space Invaders machine, struggling to get the ancient hardware working, at least as a stop gap.
          mitu Global Moderator @OneSwitch
          @OneSwitch I don't think that mirroring can be done globally - like rotating the screen can be done - , but only with a shader - as noted in https://retropie.org.uk/forum/topic/20566/.
          OneSwitchO 1 Reply Last reply Reply Quote 0
          • OneSwitchO
            OneSwitch @mitu
            @mitu You can on an HDMI monitor, but I'm not smart enough to work out how to do it (if possible) on a CRT monitor. I've heard recalbox can do it, but I'd rather stick with RetroPie if I can at this stage. This works right now in my Space Invaders...
            disable_overscan=1
            hdmi_ignore_edid=0xa5000080
            hdmi_drive=2
            hdmi_group=2
            hdmi_mode=69
            display_hdmi_rotate 0x20000
            dtparam=audio=on
            gpu_mem_256=128
            gpu_mem_512=256
            gpu_mem_1024=256
            overscan_scale=1
            This works well in Pi2Scart for everything but for being a flipped image:
            # http://rpf.io/configtxt
            #hdmi_safe=1
            disable_overscan=0
            #overscan_left=32
            #overscan_right=32
            #overscan_top=0
            #overscan_bottom=16
            # overscan.
            #framebuffer_width=1280
            #framebuffer_height=720
            #hdmi_force_hotplug=1
            #hdmi_group=1
            #hdmi_mode=1
            #hdmi_drive=2
            # no display
            #config_hdmi_boost=4
            # uncomment for composite PAL
            #sdtv_mode=2
            #arm_freq=800
            #dtparam=i2c_arm=on
            #dtparam=i2s=on
            #dtparam=spi=on
            # Uncomment this to enable the lirc-rpi module
            #dtoverlay=lirc-rpi
            dtparam=audio=on
            gpu_mem_256=128
            gpu_mem_512=256
            gpu_mem_1024=256
            overscan_scale=1
            # pi2scart only
            dtoverlay=vga666
            # crt settings
            disable_audio_dither=1
            enable_dpi_lcd=1
            display_default_lcd=1
            dpi_group=2
            dpi_mode=87
            hdmi_timings=320 1 10 20 54 240 1 6 8 10 0 0 0 60 0 6400000 1
            display_rotate=1 #UNCOMMENT THIS LINE FOR HORIZONTAL GAMES
            Obviously, a CRT TV would look far more original, in a reliable way in my Space Invaders, as for other people too trying to bring life back to these 40 year old machines. And other mirrored games of which there are quite a lot.
            • Y
              youxia
              It's quite a specific request. You can try to ask on Arcade Forge's facebook page.
              • OneSwitchO
                OneSwitch @youxia
                @youxia I don't use Facebook, but I have sent them an e-mail. If I get any luck, I'll post it back here.
                • Y
                  youxia
                  Yeah, I got similar problem. Don't use fb but have some questions for them. I think I will need to use my aunt's account :)
                  • OneSwitchO
                    OneSwitch
                    Space Invaders mirrored effect
                    I'll pass this thread onto Jochen at Arcade Forge too by e-mail. Basically, the hope is to be able to flip the image, as seen in this image of a Space Invaders machine in the bottom-most CRT screen. But not just for the game, but the entire Raspberry Pi display. So the RetroPie menu screens are the correct way around in a mirror, as well as the games, vertically, on a CRT screen through Pi2Scart. That would be fantastic.
                    • OneSwitchO
                      OneSwitch
                      Had this from Jochen at Arcade Forge:
                      "I have digged the SDL 1.2 and SLD 2 libs. I think it's not possible to get with standard libs to solve this task. So this will be a real head scratcher for the front end developers. I doubt that someone will write a piece of code to support that. Its difficult."
                        grant2258 Banned
                        there is code in mame2003_plus and mame2003 that does this it would need to be done per core though you can certainly add a bit of code yourself to mame2003 or plus to get space invaders output like this.
                        • OneSwitchO
                          OneSwitch @grant2258
                          @grant2258 Top post explains it a bit more. I can already get the game flipped on a CRT TV. I can't get Emulation Station flipped too. Flipped to work if viewed in a mirror.
