    Emulators Not Displaying
    20 Posts 6 Posters 45.8k Views
      DeadAggressor
      Pi Model: 3B
      RetroPie Version Used: 3.8.1
      Built From: Source
      USB Devices connected: Logitech K400r Keyboard & Microsoft 360 Wireless Receiver
      Controller used: Microsoft 360 Wireless
      Error messages received: None that I know of.
      Guide used: N/A
      File: N/A
      Emulator: GameGear, Gameboy {Original, Color, & Advance}, Genesis, Mastersystem, N64, NeoGeo Pocket, PSP, & SNES
      Attachment of config files: N/A
      How to replicate the problem: N/A
      I am unable to get any of the aformentioned emulators to display in Emulationstation. I currently only have Reicast working. All roms are in their correct folder following the correct file type. I've searched the forums and any topics refering to missings emulators has not help rectify my issue at the moment. Any help correcting this would be greatly appreciated.
        pimpmaul69
        Are they zip files? If so the the es_systems.cfg file would have to be looking for .zip files. Otherwise you need to unzip the files.
          DeadAggressor
          All the files are the correct file type that the .cfg is looking for.
          • FloobF
            Floob
            If you are using 3.8.1 its very unlikely the emulators themselves are missing. They should just need to have the roms present.
            So when you are in Emulation Station you dont see the GameBoy banner at all?
            Can you type this at the command line to confirm they (roms) are there?
            ls -lah /home/pi/RetroPie/roms/gameboy/
              DeadAggressor
              Sorry for the late reply I've been underway for the past couple of days. The directory gameboy doesn't exist. I have gb, gba, and gbc. All have roms in them with the correct extension. I also searched the other directories with roms that I installed and they all show up being there.
                DeadAggressor
                The fact that I have it installed on top of Raspbian wouldn't be causing this issue would it?
                • FloobF
                  Floob
                  Sorry, yes I meant gb, not gameboy.
                  It shouldnt be an issue the way you installed it.
                  When you run the retropie setup script, which gb emulators are shown as installed?
                  https://github.com/retropie/retropie-setup/wiki/updating-retropie
                    DeadAggressor
                    There aren't any specific Gameboy emulators, but I have lr-gambatte, lr-gpsp, lr-mgba, lr-vba-next, gpsp, and lr-tgbdual installed currently.
                    • FloobF
                      Floob
                      What does this show you?
                      ls -lah /home/pi/RetroPie/roms/gb
                        DeadAggressor
                        When I type that command it displays all the roms I currently have in that directory. I also typed that command for all of the emulators I currently have roms for and they all show up as well.
                        • FloobF
                          Floob
                          Do you have a couple of example filenames?
                          Have you tried using the RetroPie image instead of building from source?
                            DeadAggressor
                            Final Fantasy Adventure (USA).gb and Final Fantasy Adventure (USA).zip. I haven't tried from the image yet. Where I'm currently at for the next couple of months I need a web browser to connect to the internet so I need Raspbian for as far as I know unless there is a browers for RetroPie or EmulationStation.
                            • FloobF
                              Floob
                              The image includes Raspbian, thats the OS. Then the RetroPie scripts are on top of that.
                              But yes, there isnt an X window system pre-installed on the image.
                              I'm not sure why they arent showing up for you, unless its a permission related issue.
                              Are they all accessible by user pi?
                              Did you follow these steps exactly?
                              https://github.com/RetroPie/RetroPie-Setup
                                DeadAggressor
                                Yes, I followed those instructions exactly.
                                  BuZz administrators
                                  please post (via a pastebin site or formatted in a code block on the forum) the contents of /etc/emulationstation/es_systems.cfg and any .cfg / .log files in /home/pi/.emulationstation (change the pi user if you installed under another)
                                    DeadAggressor
                                    http://pastebin.com/tF3bjWiT /etc/emulationstation/es_systems.cfg
                                    http://pastebin.com/WssAzQg8 /home/pi/.emulationstation/es_input.cfg
                                    http://pastebin.com/Xh0McFMG /home/pi/.emulationstation/es_settings.cfg
                                    http://pastebin.com/k3hQvr8a /home/pi/.emulationstation/es_systems.cfg
                                    http://pastebin.com/uVwyan3P /home/pi/.emulationstation/es_temporaryinput.cfg
                                    As you requested BuZz.
                                      BuZz administrators
                                      I see the problem.
                                      The problem is you have enabled ParseGamelistOnly - which will mean it doesn't scan for roms and only shows items from scraped gamelists. Hence your roms are not showing up.
                                      https://github.com/retropie/retropie-setup/wiki/FAQ
                                      Parse Gamelists Only: If on, it will only read the roms you have scraped, so if you add any new roms it will not look for them unless you turn this back off. it is off by default.
                                      also - are you aware any es_systems.cfg in /home/pi/.emulationstation will override the retropie-setup generated /etc/emulationstation/es_systems.cfg - you probably dont want that unless you are happy to maintain it manually.
                                        DeadAggressor
                                        That fixed my issue. All the emulators are now showing up, thank you very much for the help. Thank you all for your assistance with this matter.
                                          bmulligan
                                          I did a lot of searching for the answer to this. Glad it's still here.
                                          I must have tweaked this setting a while ago and forgot about it.
                                          T 1 Reply Last reply Reply Quote 1
                                            TobyKanobie @bmulligan
                                            @bmulligan
                                            From your previous comment. If I where to accidently change permissions how would I go about fixing it? My problem is my emulators aren't showing up. All my files are in order but I have noticed my /home/pi/.emulationstation/es_systems.cfg
                                            does not update automatically when I install a new package I have to do it manually. It worked for nds but can't seem to get it to work for snes. But I do remember accidently messing with permissions before hand at some point.
