    Retroarch and Joypad problems (solved)
    retroarchjoypad
    37 Posts 3 Posters 7.2k Views
      Try clearing up the /home/pi/.config/retroarch/autoconfig/ folder and leave only the .cfg files - you should have one for each one of your controllers. See if this time the right configuration is picked up.
        CapNinja @mitu
        @mitu said in Retroarch and Joypad problems:
        my path is kinda different on my Pi folder. There is only "hascheevos", "RetroPie", "RetroPie-Extra" and "RetroPie-Setup".
        How can I see this "/.config/"?
        I'm using WinSCP, but can use Putty too.
          CapNinja @CapNinja
          @CapNinja said in Retroarch and Joypad problems:
          This is part is for the people from future, people who probably did the same mistakes. To follow Mitu advice I needed to learn two things
          I used Putty to see that folder, on there:
          to delete files
          rm myFile.txt
          to delete folders
          rm -rf foldername/
          Now I need to thank this person who help lost souls like me.
          Thank you very much @mitu my problem is solved. For learning reasons I just want to understand your line of thought, can you please explain to me?
            @CapNinja said in Retroarch and Joypad problems (solved):
            You updated your auto-configuration profile from RetroArch, this downloaded the .cfg files from https://github.com/libretro/retroarch-joypad-autoconfig to the /home/pi/.config/retroarch/autoconfig/ folder. The same folder also holds the RetroPie generated gamepad configuration files, the difference between them is that the ones shipped by Libretro don't have a hotkey assigned.
            When starting, RetroArch prioritised loading the Libretro config file (this one) so deleting that file - along with the other profiles which might apply to your other controllers - will make RetroArch load the correct .cfg file - the one produced by the RetroPie scripts.
              Clyde @CapNinja
              to delete files
              rm myFile.txt
              to delete folders
              rm -rf foldername/
              For the you and others from the future: For such file operations, you can also start a text-based file manager by entering mc (Midnight Commander). Just mentioned as another option to the console commands and their simplistic might. 😌
                CapNinja @mitu
                @mitu suddenly my problem came back and said "THIS IS NOT EVEN MY FINAL FORM!".
                I played with every control to test and it was fine yesterday, and today too. But was 1p games, and my kid wanted to play some Mickey game (that Mickey & Donald from snes). After choosing 2p suddenly the configuration was all wrong again.
                Now my PS4 controller works fine, but the 2 8bitdo is all messed up.
                And my shader options reset everytime, even with "core override"
                  mitu Global Moderator @CapNinja
                  Check if you have any extra auto-configuration configuration files for the 8bitdo in the auto-config folder.
                  Shaders pre-sets are not saved from the core overrides, but with the 'Save Shader pre-set' option from the 'Shaders' menu.
                    CapNinja @mitu
                    @mitu said in Retroarch and Joypad problems (solved):
                    I have one for each controller in that folder
                    It wasn't working properly (I've created a topic talking about it not much time ago) and override was a workaround to set it, but I've tried and it worked like it should.
                      Do you have any controller remapping set-up ? Maybe you've re-mapped the 2nd player controls ? Check the /home/pi/.config/retroarch/config/retroarch/config/remaps/ folder and see if you've set any such re-mapping.
                        CapNinja @mitu
                        @mitu no remaps
                          Clyde @CapNinja
                          This is the thread. Just for the record. :)
                            CapNinja @Clyde
                            @Clyde thanks man. Re-reading my stuff... Oof, it's so hard write in another language. I understand and I listen, but speak...
                            Even using Google translator before post something my texts go out so poorly written.
                            I'm sorry :'(
                              @CapNinja It's ok, you're better than google translate so far :). For your original problem though, I have no idea what could interfere with the player 2 bindings (especially since the same gamepad works as P1).
                                CapNinja @mitu
                                Your kindness is very much appreciated, thank you :)
                                Here is the catch, isn't working as P1 anymore too. And if it's unknown territory for you, may I be a guinea pig for this problem. I will accept any suggestion for anything, even if I need to format later.
                                What I wanna try to do is directly edit the .cfg for that controller located on that folder.
                                Private Noob here is going to war, good night from Brazil.
                                  If you re-configure the controller from Emulationstation, the .cfg file for the controller would be re-created with the new configuration.
                                  C 2 Replies Last reply Reply Quote 0
                                    CapNinja @mitu
                                    @mitu didn't work
                                      CapNinja @mitu
                                      @mitu one success for us. The edition on that .cfg worked. One interesting thing I've noticed is: every value was 11 more than normal.
                                      If my select button value is 10, on that .cfg he was 21.
                                      If my B button value is 4, there was 15.
                                      On a side note, I've used @Clyde "mc" tip and man, it saved at least 1h of my time.
                                      Again, guys. Thanks for your time, for your effort, for your attention and for caring and sharing your knowledge with us.
                                      I request now my promotion to Private 1st Class Noob.
