    System Select Is Always Wrong
    system screen
    19 Posts 4 Posters 1.6k Views
      AlphaBetaPie
      Having a weird problem. So I looked up how to edit the sort order the consoles appear in at first load. By default, it's alphabetically. I like my NES to be first. Simple enough, just copied/pasted the brackets from the NES to the top of the list, cleaned up the old one and BOOM! Worked like a charm.
      Except now, when I select NES at first load, it goes to the wrong menu. If I back up and do it again (or if I scroll left/right first before making a selection at first load), it will work fine. Did I miss something somewhere? Why does it point to the wrong menu at first load when selecting the system in a custom sort order?
        mitu Global Moderator @AlphaBetaPie
        @AlphaBetaPie Post the file you modified on pastebin.com to see what may be wrong.
          AlphaBetaPie
          Sure, here you go. Was a pretty simple copy/paste job, so not sure I fubared anything. But you can double check for me: https://pastebin.com/nqhBrNMV
            It looks ok. What do you mean by 'selecting the wrong menu' ?
              AlphaBetaPie
              Will post video soon
                AlphaBetaPie
                ~UPDATE~
                OK, I did a little more experimenting, and narrowed one thing down (and discovered something else REALLY weird).
                First, it seems related to my 8BitDo pad. At boot, my RetroPie defaults to my custom console screen order of NES in the center, with the Amiga being to my right, and the Retropie settings to my left (these are the three menus that come pre-loaded). If hit select on my wireless USB keyboard, everything it fine. It goes down one level into the NES game select screen (which is what it should do). But if I try this exact same thing with the game pad, it jumps one screen to the left AND down into the settings menu (without evening having to hit the button twice, I just ended up in settings by hitting select on the pad).
                The second weird thing is, using the pad reset some of my settings in my retropiemenu.xml. I edited the X and Y values to move the icons over to the right, and now they are rest back to where they were before. Why in hell this pad is wreaking that kind of havoc in such weird places is beyond me. I assume if I made a copy of this and moved it somewhere, this won't happen?
                Anyone ever have this sort of weirdness?
                  Hm, sounds like ghost inputs - does the gampad have a joystick ? You could 'un-configure' them in Emulationstation and see if the joystick is ignored.
                  For the other problem, I don't really understand what happens - it's only when using the 8bit do gamepad that the help menu is 'broken' ?
                    AlphaBetaPie @mitu
                    @mitu UPDATE:
                    OK, I have been able to confirm something. I had some other settings I wanted to test from a fresh build, so I formatted my SD card and re-flashed my RetroPie image so everything was completely fresh (and default). I only tweaked few necessary settings (like setting up my settings to use SSH and Wi-Fi, set the resolution, turned off overscan, etc). I then immediately connected the 8BitDo Sn30pro Bluetooth game path to the pie (wanted to have it connected early to eliminate any of the changes I had made way later on).
                    I can confirm it's the pad for some reason. Even on what is basically a complete default system, it still drills down and one menu over when I simply his the select key. Nothing about my pie's setup has been changed that would affect this (to the best of my knowledge).
                    So other than changing game pads, not sure what else I can do. Anyone ever report these kinds of problems with the pad? Unless there is something I'm missing on the Retropie side.
                      @AlphaBetaPie said in System Select Is Always Wrong:
                      Not when using the Select button, but I've seen a few posts about ghost inputs from the joypads/d-pad, I don't recall if they were related to any particular model of gamepad.
                        Clyde
                        *rummages his bookmarks*
                        https://retropie.org.uk/forum/topic/8187/gamepads-making-involuntary-movements-in-emulation-station
                        At least one controller could be fixed by replacing some capacitors on its board. See here and here and here.
                        Apart from that, external bluetooth adapters fixed the issue for some people, including me.
                          Actually I was thinking more on the line with this issue - https://www.raphnet-tech.com/support/retropie/index.php. If it would have been persistent ghost issues, I assume @AlphaBetaPie would have noticed this during operation or gameplay, since it would appear randomly, not only on the first connect/activation.
                            Clyde @mitu
                            @mitu I never noticed the ghost inputs of my Wii U Pro clones in games, only in ES when it did something out of the blue by itself like scrolling through the games or changing the system. I guess the action in most arcade games may overlap any occasional short ghost input in the eyes of the player, or I mistook them for my own inability. So like me, @AlphaBetaPie may not have noticed them outside of ES. 🙈
                            I concur about the randomness we would have to expect in this case, though.
                              AlphaBetaPie
                              In my experience, this only happens once at first load. Once the gamepad is engaged, it does not do this any more. It's just the first button press of the "A button" that makes it go down and to the right/left of the wrong menu, instead of just straight down. Also, if I hit any other button first before I select (again, to engage it or "wake it up" I guess you could say), then it works fine and goes where it's supposed to go on first press. So weird...
                                AlphaBetaPie
                                Also...
                                I'm willing to try the separate bluetooth receiver idea mentioned above, as my local PC store has them for like $15. How would I set this up? I know it has a place in the menu to un-sync any attached bluetooth devices. I assume the new adapter is just plug and play. But how do I disabled the on-board bluetooth on the raspberry pie to ensure the new adapater is what the controller syncs to now?
                                mituM ClydeC KN4THXK 3 Replies Last reply Reply Quote 0
                                  Should be.
                                  Just add a line to the config.txt file on the SD card with
                                  dtoverlay=pi3-disable-bt
                                  and this should disable the on-board bluetooth.
                                    Clyde @AlphaBetaPie
                                    @AlphaBetaPie My Mayflash wireless adapter has a sync button like the bluetooth gamepads do, too. To sync them, I have to press the button on the adapter first, and then the button on the gamepads. Done. They stay synced until I sync the gamepad to another host.
                                    After that, I just have to wake up the gamepad by pressing one of its normal buttons while the adapter is plugged into a USB port, and it will connect within seconds.
                                    The adapter itself works out of the box in Retropie.
                                    • KN4THXK
                                      KN4THX @AlphaBetaPie
                                      @AlphaBetaPie Out of curiosity, is this happening on a 3B or a 3B+?
                                      "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
                                        AlphaBetaPie
                                        So I did try disabling it using the line of code, which did work. I picked up a ASUS plug n' play Bluetooth adapter, which also worked in connecting. But it still does the same thing. So that eliminates that. I have just switched back to a USB cable controller for now. I'm going to try some of the other models 8BitDo has. Maybe it's just this one that is weird.
                                        Also, I think the board I'm using is the plus model.
                                          Clyde @AlphaBetaPie
                                          @AlphaBetaPie You can check your Raspi model with this command:
                                          cat /proc/device-tree/model
