    Scraping Mame roms using skyscraper v3.3.5
    skyscraperemulationstaton
    9 Posts 3 Posters 859 Views
      Jimi007
      Hi
      Pi Model or other hardware: Raspberry Pi 3B+
      Power Supply used: Official Pi Power Supply
      RetroPie Version Used 4.5.1
      Skyscraper v3.3.5
      My question is regarding to scraping rom names and videos.
      Rom names are listed as name.zip etc
      When rom images are scraped it changes the names to the official name plus the version eg Robocop (Japan) , 19XX: The War Against Destiny (USA 951207) , 1942 (First Version)
      When rom videos are scraped it changes it to just the name eg Robocop , 1942 etc so there would be three or four roms with the same name.
      Is there any settings in Skyscraper which can scrape the name and version with the videos?
      Or do I just need to go through and edit the gamelist.xml manually
      Regards
      Jimi
      muldjordM 1 Reply Last reply Reply Quote 0
      • muldjordM
        muldjord @Jimi007
        This post is deleted!
        • muldjordM
          muldjord
          Are you using the --symlink option? Then that might be the reason.
          EDIT: No, that's probably not it. I have been rummaging through the code for the video export and it uses the complete basename + video format suffix as filename. I have no idea how you have managed to make it save it without that.
          EDIT2: Actually, rereading your question again, I am not sure exactly what you are asking. Are you talking about filenames or gamelist names? If you are talking about gamelist names, what do you mean by:
          ? What does it change? The video export filename? Or the gamelist filename? And if so, what does that have to do with the video file? I am confused.
            Jimi007 @muldjord
            @muldjord I'll try and explain it a bit better.
            So I basically scraped Roms using just the image option.
            I then ran the create gamelist
            When I load retropie and view the mame list it displays the Rom names with the type after.
            E.g. 1942 (japan) and shows a picture of the game
            Then I rename the gamelist.xml file
            I run the scraper with the video option.
            It scrapes the game names and downloads the game videos.
            When I view the mame list it shows the video and displays the Rom name without the type after e.g. 1942.
            It may not be the scraper itself but where it gets the info from.
            Hope this helps
            Jimi
            • muldjordM
              muldjord
              You must have something set up that I am unaware of. I just tested it with and without the --videos option and i get, for instance, <name>Mortal Kombat III (Europe)</name> both with and without that option. Do you perhaps use the --nobrackets option somewhere? That will remove everything inside () and []. But this is unrelated to the --videos option. Maybe there's an error in the RetroPie script that add the --nobrackets option whenever the --videos option is enabled. Do you run it from command-line or from the RetroPie script?
                I gave it a test trying to reproduce an error and I don't see anything related to videos to alter the default behavior. I.e.
                • have 2 different ROMs - 1942.zip and 1942w.zip
                • scraping (with or without videos) results in them having the title changed to 1942
                • video path is different, based on the ROMset name:
                 <path>/home/pi/RetroPie/roms/arcade/1942.zip</path>
                    <name>1942</name>
                    <cover />
                    <image>/home/pi/RetroPie/roms/arcade/media/screenshots/1942.png</image>
                    <marquee>/home/pi/RetroPie/roms/arcade/media/marquees/1942.png</marquee>
                    <video>/home/pi/RetroPie/roms/arcade/media/videos/1942.mp4</video>
                    <rating>0.8</rating>
                    <desc>&quot;1942&quot; is a vertically-scrolling shoot-em-up set in the Pacific theatre during World War II, in which the goal is to reach Tokyo and destroy the entire Japanese air fleet.
                The player pilots a plane dubbed the &quot;Super Ace&quot; (its appearance is that of a Lockheed P-38 Lightning) and has to shoot down waves of enemy planes while avoiding incoming enemy fire. The &apos;Super Ace&apos; can perform a limited number of rolls or &apos;loop-the-loops&apos; to evade enemy planes and shots.
                During the game, waves of red enemy planes periodically appear. If the player manages to destroy a red wave, a power-up, in the form of a &apos;POW&apos; symbol, will be dropped and can be picked up. The power-up will award either increased fire-power (doubling the player&apos;s guns from two to four), a smart bomb that destroys all on-screen enemy planes the instant it&apos;s collected, two wingmen planes that flank the Super Ace and increase fire power, or simply extra points.
                At the end of each stage the &apos;Super Ace&apos; lands on an aircraft carrier and bonus points are awarded based on player performance. &quot;1942&quot; differs from other games in that its levels are numbered in reverse order, so the game begins at stage 32 and ends at stage 1.</desc>
                    <releasedate>19840101T000000</releasedate>
                    <developer>Capcom</developer>
                    <publisher>Capcom</publisher>
                    <genre>Shoot&apos;em up / Vertical, Shoot&apos;em Up</genre>
                    <players>2</players>
                    <kidgame>true</kidgame>
                  </game>
                 <game>
                    <path>/home/pi/RetroPie/roms/arcade/1942w.zip</path>
                    <name>1942</name>
                    <cover />
                    <image>/home/pi/RetroPie/roms/arcade/media/screenshots/1942w.png</image>
                    <marquee>/home/pi/RetroPie/roms/arcade/media/marquees/1942w.png</marquee>
                    <video>/home/pi/RetroPie/roms/arcade/media/videos/1942w.mp4</video>
                  </game>
                So, if the problem is the title (name) change, then this is the default - the title from the scraping site (stored in the cache) is added to the gamelist.
                @Jimi007 did you use different scraping sources for the 2 scraping sessions ? Maybe one scraper has the title as is (i.e. including regional info), while ScreenScraper (which I've used) does not include Region info in the title (since it's stored separately).
                  Jimi007 @mitu
                  I may have to test again. Not sure why the names turned out different.
                  I am using the Screenscraper source for both options.
                  Two roms below 1942a.zip and 1942b.zip
                  @muldjord - I used the Retropie GUI to perform the scraping. First I used the option and had videos disabled
                  2nd run I enabled the video option and I used Screenscraper for both
                  Below is my results first from scraping without videos just images
                  <game>
                      <path>/home/pi/RetroPie/roms/mame-libretro/1942a.zip</path>
                      <name>1942 (Revision A)</name>
                      <cover />
                      <image>/home/pi/.emulationstation/downloaded_media/mame-libretro/screenshots/1942a.png</image>
                      <marquee>/home/pi/.emulationstation/downloaded_media/mame-libretro/marquees/1942a.png</marquee>
                      <video />
                      <desc>This Arcade Video game was published 35 years ago:
                  1942 (c) 1984 Capcom.
                  1942 is a vertically-scrolling shoot-em-up set in the Pacific theatre during World War II, in which the goal is to reach Tokyo and destroy the entire Japanese air fleet.
                  At the end of each stage the &apos;Super Ace&apos; lands on an aircraft carrier and bonus points are awarded based on player performance. 1942 differs from other games in that its levels are numbered in reverse order, so the game begins at stage 32 and ends at stage 1.</desc>
                      <genre>Shooter / Flying Vertical</genre>
                    </game>
                    <game>
                      <path>/home/pi/RetroPie/roms/mame-libretro/1942.zip</path>
                      <name>1942 (Revision B)</name>
                      <cover />
                      <image>/home/pi/.emulationstation/downloaded_media/mame-libretro/screenshots/1942.png</image>
                      <marquee>/home/pi/.emulationstation/downloaded_media/mame-libretro/marquees/1942.png</marquee>
                      <video />
                  2nd one below is from the scrape with the video option
                  <releasedate>19870101T000000</releasedate>
                      <developer />
                      <publisher />
                      <genre />
                      <players />
                    </game>
                    <game>
                      <path>/home/pi/RetroPie/roms/mame-libretro/1942b.zip</path>
                      <name>1942</name>
                      <cover />
                      <image>/home/pi/.emulationstation/downloaded_media/mame-libretro/screenshots/1942b.png</image>
                      <marquee>/home/pi/.emulationstation/downloaded_media/mame-libretro/marquees/1942b.png</marquee>
                      <video>/home/pi/.emulationstation/downloaded_media/mame-libretro/videos/1942b.mp4</video>
                    </game>
                    <game>
                      <name>1942</name>
                      <cover />
                      <video>/home/pi/.emulationstation/downloaded_media/mame-libretro/videos/1942a.mp4</video>
                  For some reason the 2nd run lost the revision of the names.
                  Regards
                  Jimi
                  • muldjordM
                    muldjord
                    I have no clue what is going on. The only thing that I can think of that can cause that is the --nobrackets option. I can't reproduce it here on my setup, so I can't even help you beyond what I've already mentioned I'm afraid.
                    EDIT: I'm not sure how advanced you are ready to go with this (I don't know your technical skill level), but it would be useful to have a look at your cache to see where those () actually come from. Running Skyscraper from command-line you can get a listing of all resources connected to the file. It is documented here. Please read the first few paragraphs on how to run it from command-line since you've installed it from the RetroPie script, and check further down for the --cache edit <FILENAME> description. It will allow you to list all resources connected to the file. Of course all of this will have to be done through an ssh session or from a local terminal.
                    EDIT2: The output of -p fba --cache show for the platform might also be useful
                      Jimi007 @muldjord
                      @muldjord I will give this a go to see if I can find out what is going on.
                      Either that or I will manually edit the files with the correct revision names from my previous scrapes.
                      Appreciate the help @muldjord and @mitu
                      Jimi
