    How to install safe shutdown script for Nespi 2 case?
    nespi case plus
    3 Posts 3 Posters 1.2k Views
      rsn8887
      Is there a new way that works to install the safe shutdown scripts for Retroflag Nespi 2 case?
      The instructions on Retroflag’s webpage don’t work anymore, the command just hangs forever in the shell trying to download something. This is the command I tried:
      wget -O - "https://raw.githubusercontent.com/RetroFlag/retroflag-picase/master/install.sh" | sudo bash
      From here:
      https://github.com/RetroFlag/retroflag-picase
        Install @cyperghost's shutdown script, it's better than RetrFlag's script anyway - https://github.com/crcerror/ES-generic-shutdown.
          cyperghost @rsn8887
          @rsn8887 You can also try
          Install Safe Shutdown script
          wget -O - "https://raw.githubusercontent.com/crcerror/retroflag-picase/master/install.sh" | sudo bash
          Uninstall Safe Shutdown script
          wget -O - "https://raw.githubusercontent.com/crcerror/retroflag-picase/master/uninstall_all.sh" | sudo bash
