    need more GPIO pin
    gpio controllergpio pin
    8 Posts 3 Posters 893 Views
    • popfaignantP
      popfaignant
      Raspberry pi3 b+
      Alim 5v 5A
      Retropie 4.5.3
      Hello everybody, I've made a bartel with joystick connected to the GPIO whith 12 buttons (⬆️⬇️⬅️➡️, start, select ,A, B, X, Y, L, R).
      So my problem is that i want another button for the Hotkey. I'seen on this forum that the pin 3 and 5 aren't usable and i don't know where i can connect my hk.
      I don't want to use select button for many reasons.
      Do you have an answer ?
        cyperghost
        Search for MCP23017 or MCP23008 this expands your GPIOs with a I2C component and costs are very low.
        popfaignantP 1 Reply Last reply Reply Quote 1
        • popfaignantP
          popfaignant @cyperghost
          @cyperghost thanks for your quick answer but on my gpio, just 12 pin are connected. It's to bad to have some pins free and can't connect my hk on these. I expected an other solution.
            cyperghost @popfaignant
            @popfaignant (Physical) Pin 3 and 5 are I2C communication pins. Imho opinion you can use them. Usually Pin5 and Pin6 are used for a cheap power button solution.
            So Pin5 works for sure.
            You can add
            dtparam=i2c_arm=off
            dtparam=i2s=off
            to your config.txt - this will disable I2C and the Pin3 and 5 should be available as GPIO 2 and GPIO 3
            popfaignantP 2 Replies Last reply Reply Quote 0
            • popfaignantP
              @cyperghost oh great, I'll try !
              • popfaignantP
                @cyperghost where is the config.txt please ?
                  mitu Global Moderator @popfaignant
                  @popfaignant Put the SD card in your PC, the config.txt file should be on the BOOT partition. Or, if you're on the Raspbian system, in the /boot folder.
                  popfaignantP 1 Reply Last reply Reply Quote 0
                  • popfaignantP
                    popfaignant @mitu
                    @mitu sorry, it doesn't work 😢
