    RetroPie Buster weekly image - problem with overscan.
    retropie busteroverscan buster
    7 Posts 3 Posters 1.1k Views
    • windgW
      windg
      I am testing RetroPIe Buster weekly image in a RPI 3B. All the emulators that i am using are working ok!.
      The only problem i have is with the overscan settings(black boarders around screen) but only when i am in the terminal or during boot. In ES everything is fine.
      Any suggestions to test and fix overscan problem are welcome. Thanks!
      Pi Model or other hardware: 3 B
      Power Supply used: Official
      RetroPie Version Used : retropie-buster-4.5.9-rpi2_rpi3.img.gz/12-Jan-2020.
      Built From: RetroPie website
      config.txt :
      .***.     Sunday, 19 January 2020, 06:16:28 PM
           *****     Linux 4.19.75-v7+ armv7l GNU/Linux
            |*|      Filesystem      Size  Used Avail Use% Mounted on
            |*|      /dev/root       6.9G  2.4G  4.2G  37% /
          ..|*|..    Uptime.............: 0 days, 01h53m33s
        .*** * ***.  Memory.............: 433564kB (Free) / 765604kB (Total)
        *******@@**  Running Processes..: 114
        `*****@@**'  IP Address.........: 192.168.1.3
         `*******'   Temperature........: CPU: 50°C/122°F GPU: 50°C/122°F
           `"""'     The RetroPie Project, https://retropie.org.uk
      pi@retropie:~ $ sudo nano /boot/config.txt
        GNU nano 3.2                    /boot/config.txt                    Modified
      # http://rpf.io/configtxt
      #hdmi_safe=1
      #disable_overscan=1
      overscan_left=-18
      overscan_right=-18
      overscan_top=-33
      overscan_bottom=-33
      fbset :
      mode "1220x690"
          geometry 1220 690 1220 690 32
          timings 0 0 0 0 0 0 0
          rgba 8/16,8/8,8/0,8/24
      endmode
      firmware:
      Sep 24 2019 17:37:19
      Copyright (c) 2012 Broadcom
      version 6820edeee4ef3891b95fc01cf02a7abd7ca52f17 (clean) (release) (start)
        Do you get the same issue with the 4.5.1 image ?
        Is that the whole config.txt - I think the RetroPie images have overscan_scale set in the config.txt file, which I don't see in your output.
        windgW 1 Reply Last reply Reply Quote 0
        • windgW
          windg @mitu
          I am using the same config.txt settings in the 4.5.1 image without overscan problems.
          Sorry, the whole config.txt :
          hdmi_force_hotplug=1
          hdmi_group=1
          hdmi_mode=19
          #hdmi_drive=2
          # no display
          #config_hdmi_boost=4
          # uncomment for composite PAL
          #sdtv_mode=2
          #arm_freq=800
          #dtparam=i2c_arm=on
          #dtparam=i2s=on
          #dtparam=spi=on
          # Uncomment this to enable infrared communication.
          dtparam=audio=on
          [pi4]
          # Enable DRM VC4 V3D driver on top of the dispmanx display stack
          dtoverlay=vc4-fkms-v3d
          max_framebuffers=2
          [all]
          #dtoverlay=vc4-fkms-v3d
          gpu_mem_256=128
          gpu_mem_512=256
          gpu_mem_1024=256
          overscan_scale=1
            Can you add back overscan_scale=1 and see if it makes a difference ?
            • windgW
              windg @mitu
              overscan_scale=1 was here from the beginning, i post the half config.txt by mistake.
              i try also to uncomment disable_ overscan = 1 and the image was bigger from the tv screen, in the teminal and in the Emulationstation.
                This kind of problem (overscan mis-match) is one of the reasons the 4.5.1 image still uses the 4.14 kernel. Unfortunately this is not a simple thing to diagnose (or report upstream), because it depends on the display used.
                If you want to pursue this further, then the place to report it would be the Raspberry PI firmware repository (github.com/raspberrypi/firmware) if you have a Github account. Before opening an issue there, you should try the latest kernel/firmware by using rpi-update, just to make sure the issue hasn't been already fixed in a recent update.
                • herb_fargusH
                  herb_fargus administrators @mitu
                  @mitu I can personally confirm an rpi-update fixed the overscan settings on my Samsung. Obviously I don't recommend rpi-update as it can cause other system issues but in this case overscan was a specific issue it fixed for me.
