    Roms won’t load
    roms won’t load
    10 Posts 2 Posters 592 Views
      jkeefe56
      Hi, I know this gets asked a lot but I’ve been googling it for two days to no avail....
      Did a manual install from raspian desktop and retropie looks good but the roms won’t load (takes me back to game select screen).
      Model or other hardware: pi 3b v1.2
      Power Supply used: novatel 10w/5v/2a
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.5.10
      Built From: Manual Install from this websites instructions, then chose basic install
      USB Devices connected: wireless keyboard only for now
      Controller used: keyboard
      Error messages received:
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-snes9x2010/snes9x2010_libretro.so --config /opt/retropie/configs/snes/retroarch.cfg "/home/pi/RetroPie/roms/snes/Earthbound (U).smc" --appendconfig /dev/shm/retroarch.cfg
      /opt/retropie/emulators/retroarch/bin/retroarch: symbol lookup error: /usr/lib/arm-linux-gnueabihf/neon/vfp/libavcodec.so.58: undefined symbol: bcm_host_is_fkms_active
      Guide used: (Mention if you followed a guide) guide on this website for manual install
      File: I’ve tried 4 or 5 different ones. All worked on desktop and wii emulator, none load here (nes, snes, n64 and atari plus I tried two genesis games that were untested...none worked)
        RetroPie doesn't work on the desktop version of Raspbian, you need to use the Raspbian Lite (i.e. no desktop) variant. Which version of Raspbian did you use ?
          jkeefe56
          I believe it’s 4.19.57 (one of those preloaded canakit cards as I don’t have another home pc at the moment to flash sd cards with). I do exit the desktop before launching retropie and like I said all seems well until trying to load a rom.
            Try updating your kernel and firmware, do an
            sudo apt-get update
            sudo apt-get upgrade
            and re-try.
              jkeefe56 @mitu
              @mitu it’s still not working, however the upgrade did have a few “failed to fetch” on the bottom on for chromium, one for libraspberry and one for the kernel. So,...I’ll keep trying.
                jkeefe56
                I did sudo apt full-upgrade and that fixed those errors, but the rom still won’t load. Same error in runcommand.log
                  It looks like something didn't get upgraded. Can you post the output of the 2 commands below:
                  apt show libraspberrypi0
                  nm /opt/vc/lib/libbcm_host.so | grep bcm_host_is_fkms_active
                    jkeefe56
                    the second command didnt do anything, the first gave this...
                    pi@raspberrypi:~ $ apt show libraspberrypi0
                    Package: libraspberrypi0
                    Version: 1.20200114-1
                    Priority: optional
                    Section: libs
                    Source: raspberrypi-firmware
                    Maintainer: Serge Schneider serge@raspberrypi.org
                    Installed-Size: 3,257 kB
                    Depends: raspberrypi-bootloader (= 1.20200114-1)
                    Homepage: https://github.com/raspberrypi/firmware
                    Download-Size: 848 kB
                    APT-Sources: http://archive.raspberrypi.org/debian buster/main armhf Packages
                    Description: EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's VideoCore IV
                    This package contains implementations of EGL, OpenGL ES, OpenVG, OpenWF
                    Composition, and others for the Raspberry Pi's VideoCore IV multimedia
                    processor.
                    N: There is 1 additional record. Please use the '-a' switch to see it
                    pi@raspberrypi:~ $ nm /opt/vc/lib/libbcm_host.so | grep bcm_host_is_fkms_active
                      Unless something happened with the latest Rasbian updates, I think there's something wrong with the libraspberrypi0 package installation on your end. Try to re-install it with
                      sudo apt install --reinstall libraspberrypi0
                        jkeefe56
                        Thank you so much! It’s working now! Thanks again for the help!
