    Updating issues with RetroPie on RPi 4 issues?
    retropie
    50 Posts 10 Posters 1.6k Views
    • djchewmaccaD
      djchewmacca
      I recently installed the latest weekly build from the 26th of January then updated it. When it reboots it fails to start. It gets stuck at the 4 raspberries screen. I made the RetroPie image into a noobs type so I could dual boot it if that could be the cause. I can manually update the main, core, optional parts and it's fine. I think it has something to do with when it updates the kernel part.
      Thanks and keep up the great work!!!
        Did you overclock your system ? Remove the overclock.
        djchewmaccaD 2 Replies Last reply Reply Quote 1
        • djchewmaccaD
          djchewmacca @mitu
          @mitu I did overclock. Never had issues with overclocking. I've got one of those Argon One cases and it keeps it really cool.
          • djchewmaccaD
            djchewmacca @mitu
            @mitu Just removed the overclock and it works. Why would that make a difference now than before?
            • quicksilverQ
              quicksilver @djchewmacca
              @djchewmacca it has nothing to do with your case or overclock stability. A recent firmware update has added a system that reduces power usage and heat. However a side effect is that it's now impossible to overclock the GPU. Remove any GPU related overclocks if you want your system to boot.
              djchewmaccaD 1 Reply Last reply Reply Quote 1
              • djchewmaccaD
                djchewmacca @quicksilver
                @quicksilver Thanks. I'll do that. Much appreciated.
                • IceChes1I
                  IceChes1
                  Is there a way to bypass this? Delete a file or something?
                  HOME CONSOLE
                  Pi 4
                  SanDisk 64 GB
                  Master branch install
                  3.5 amp CanaKit PSU
                  Logitech F310, Dell keyboard, Dell mouse, JetFlash Transcend 16 GB USB stick
                  HANDHELD
                  Pi 0 W
                  SanDisk 32 GB
                  Random image I found. Had a driver I needed.
                  IPEGA PG-9157 USB Receiver
                  • George SpiggottG
                    George Spiggott
                    Does losing the overclock on the GPU have a significant effect on performance?
                    Also is there a guide to installing the nightly update anywhere ?
                    Currently running:
                    Retropie 4.8.9 on a Pi Zero 2W (Overclock Settings: CPU 1400Mhz)
                    ES-DE on a GMKtec K6 (Windows 11, 32GB RAM)
                    djchewmaccaD quicksilverQ 2 Replies Last reply Reply Quote 0
                    • IceChes1I
                      IceChes1
                      Yes to both questions. For your first question, only on newer consoles like N64 and PS1. For your second-
                      There are nightly pre-made builds here
                      HOME CONSOLE
                      Pi 4
                      SanDisk 64 GB
                      3.5 amp CanaKit PSU
                      HANDHELD
                      Pi 0 W
                      SanDisk 32 GB
                      • IceChes1I
                        IceChes1
                        Uh, wait, that wasn't the right URL...
                        HOME CONSOLE
                        Pi 4
                        SanDisk 64 GB
                        3.5 amp CanaKit PSU
                        HANDHELD
                        Pi 0 W
                        SanDisk 32 GB
                        • IceChes1I
                          IceChes1
                          Here you go
                          HOME CONSOLE
                          Pi 4
                          SanDisk 64 GB
                          3.5 amp CanaKit PSU
                          HANDHELD
                          Pi 0 W
                          SanDisk 32 GB
                          • djchewmaccaD
                            djchewmacca @George Spiggott
                            @George-Spiggott Probably won't be that much of a significant difference. I was only able to overclock my GPU to 600MHz anyway. If I tried to push it further it would clock at 500MHz anyway. As long as I can still overclock the CPU i am not that bothered. I have the CPU in mine clocked at 2147MHz. Runs perfectly fine with the active cooling i have got going. :)
                            • quicksilverQ
                              quicksilver @George Spiggott
                              @George-Spiggott I have tested many N64 and Dreamcast games using (GPU) 500 vs 600 MHz and while monitoring the fps I could not find any significant difference. I'm not so sure that the pi 4 GPU is a bottleneck like previous pi models. Or at the very least 100 MHz doesn't make an appreciable difference.
                              @IceChes1 said in Updating issues with RetroPie on RPi 4 issues?:
                              Makes no difference for pcsxrearmed, it's pretty much completely CPU driven (iirc). This is why it's worked so well since the pi 2. I'm also not convinced that it's that big of a help for N64 either.
                              • George SpiggottG
                                George Spiggott
                                Thanks guys
                                I'm running a 3rd party Retropie image at the moment and I'd like to come back to something that is official ASAP The weekly builds will be just fine in that regard.
                                How about PSP? PSP is certainly the most graphically advanced of the higher end systems that Retropie supports? Although if Dolphin/Gamecube is any indicator of how the Pi4 handles higher end graphics it is probably worth noting that increasing the resolution on Gamecube games has little effect on the emulation speed (very slow doesn't get much slower).
                                Currently running:
                                • IceChes1I
                                  IceChes1
                                  Wait, you put dolphin on a Pi 4 with RetroPie?
                                  HOME CONSOLE
                                  Pi 4
                                  SanDisk 64 GB
                                  3.5 amp CanaKit PSU
                                  HANDHELD
                                  Pi 0 W
                                  SanDisk 32 GB
                                  George SpiggottG 1 Reply Last reply Reply Quote 0
                                  • quicksilverQ
                                    @George-Spiggott I have tested a few PSP games and many run well on my pi4. A few others I had to turn on a little frame skipping to keep the games from slowing down. Hopefully once the new Mesa drivers are incorporated into retropie we can start getting some more optimized builds of PPSSPP, mupen64plus etc. No clue if it will make much of a difference but here's hoping.
                                    • IceChes1I
                                      IceChes1
                                      PSP games run very well.
                                      HOME CONSOLE
                                      Pi 4
                                      SanDisk 64 GB
                                      3.5 amp CanaKit PSU
                                      HANDHELD
                                      Pi 0 W
                                      SanDisk 32 GB
                                      • George SpiggottG
                                        George Spiggott @IceChes1
                                        Sadly not. I have a Gentoo 64 build with Dolphin on it. Playing Dolphin/Gamecube on a Pi4 is like playing the slowest N64 game on a Pi3.
                                        Currently running:
                                        • quicksilverQ
                                          @George-Spiggott said in Updating issues with RetroPie on RPi 4 issues?:
                                          Thanks for being a guinea pig. Means I don't have to bother with trying it. ;)
                                          • IceChes1I
                                            IceChes1
                                            I'm planning on getting it anyway. And when I do I am going to overclock.
                                            HOME CONSOLE
                                            Pi 4
                                            SanDisk 64 GB
                                            3.5 amp CanaKit PSU
                                            HANDHELD
                                            Pi 0 W
                                            SanDisk 32 GB
