    Request : Help on Dos box
    dosbox
    42 Posts 3 Posters 5.5k Views
    • E
      escc1986
      I'm new to dos box
      I have this game " Willy Bemish " The cd version with all the files
      I renamed the folder to Willy
      I put all the cd files in there including the "WILLLY.exec"
      I made a Willy.bat file so it could be viewed in the PC games menu
      I now get to Willy options
      I click the Willy and it loads nothing and returns to the menus
      I click the second Willy and it brings me up an install menue ( I didn't know what to do , so I pressed installed ) and it's done and returns to the main menus
      So I'm not sure what to do
      Hope it's not too hard
      Thank you for any help
      • quicksilverQ
        quicksilver @escc1986
        @escc1986 what format is the CD image? Is it an .iso?
        • E
          escc1986 @quicksilver
          @quicksilver
          It was an ISO
          I extracted the ISO
          To get all the files inside including the .EXE
          So not an ISO , just all the files inside of the folder labeled "willy"
          • E
            escc1986
            I Apologize
            I guess I should of mentioned
            I'm using retropie
            Includes Emulation station
            With the dosbox emulation I'm using for the PC games
            All my other dos games work fine but then again I don't have any CD format games only Floppy game files
            So I guess I don't know how to install this CD based Games
            " The Adventures of Willy Bemish "
            • E
              escc1986
              If anyone is curious
              Here is a video of my problem
              https://dropmefiles.com/tiqam
              • E
                escc1986
                Hi
                Im In Need Of Some Help
                I'm Using Retropie , With Emulationstation ( an Image I Grabbed online)
                Under my PC Games Menue I have a ton of games , all dos floppy games no CD Games
                (On PC under /roms/PC All games Are in there folder and at the root each game has a .bat file for it to be shown to run the game
                I Want to install a CD game ( The Adventures of Willy Bemish)
                I'm not sure how to do this
                I have the game in a folder (no ISO) lots of files including the WILLY.exe file
                I then make a .bat for the game and place it the root of the /roms/pc
                I then place the willy folder (Game file ) also in the root of the directory /roms/pc
                I restart emulationstation
                Now it shows up 2 Willy files to choose in PC games menu
                I click the 1sr one , nothing happens , it loads then returns to me the menu
                I click the 2nd, it loads and brings up the installation screen , (i didn't know what to do , I just pressed continue and it said install complete ... then it returned to the PC games menu
                Now I click the 1st Willy again and nothing happens , loads and reruns me to the menu
                I'm New to all this and not sure what I'm doIng wrong
                Hope someone will be able to Help me
                Here is a link of a video of my issue
                Hope someone is able to help
                  mitu Global Moderator @escc1986
                  @escc1986 Please don't post multiple topics for the same problem. I've merged your new topic with the previous one.
                  When posting a support topic, please add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first to your post.
                  • quicksilverQ
                    quicksilver
                    You don't want to extract the files from the iso. We need to mount the .iso as if it's loaded in a CD ROM drive. Probably best to start over, what are the original files you are working with? Can you post a picture of the directories?
                    • E
                      escc1986 @mitu
                      I do apologize for the repost , I felt I didn't explain myself well enough in the first post
                      Thank you for the help to merge
                      I do apologize for the mistake
                      • E
                        @quicksilver
                        Ok I'm kind of confused ...
                        Don't know what or how to mount
                        and not sure what you meant about the ISO
                        Here is a picture of the directory of my willy folder now
                        https://dropmefiles.com/G1JG3
                        If you could explain step by step on what I should do would help me a lot
                        Thank you for the replys to help
                        • E
                          escc1986 @escc1986
                          @escc1986
                          I guess you could say another BIG issue I'm having
                          Is
                          I don't know how to get to the command line of Dos box ?
                          Or I don't know how to launch dos box to get the command line
                          Because if i need to mount something I'm sure in need the command line in dos box
                            @escc1986 said in Request : Help on Dos box:
                            The first entry in the pc system is +Start DOSbox - this is what you can run to get a DosBox command line.
                            • E
                              escc1986 @mitu
                              Alright from my Main Retropie screen
                              I pressed start then
                              "Quit Emulationstation"
                              I then was in command line
                              I typed : +Start DOSbox
                              and it said command it found
                              Here is picture (please let me know what I did wrong )
                              https://dropmefiles.com/bLsAE
                                Who said anything about quitting EmulationStation ? You go to the PC (or MSDOS) system in EmulationStation, where you have copied your game, and there you have the +Start DOSBox entry:
                                • E
                                  escc1986 @mitu
                                  My Apologias
                                  Unfortunately I do not have that option when I see go into the PC Menu
                                  https://dropmefiles.com/3wcfU
                                  • quicksilverQ
                                    @escc1986 did you configure this image yourself? Or is this a pre-configured image that you downloaded with games already on it?
                                    • E
                                      @quicksilver
                                      This was an already made image
                                      • E
                                        escc1986
                                        Ok ... I found out how to start dosbox on my retropie
                                        I then typed
                                        cd /opt/retropie/emulators/dosbox/bin (enter)
                                        Then I pressed : sudo ./dosbox (enter) To start dosbox
                                        • quicksilverQ
                                          @escc1986 we can't support third party images. See: https://retropie.org.uk/forum/topic/3/read-this-first
                                          If you want troubleshooting help youll need to start with the official stock image. Otherwise you'll need to ask the that image's creator for help.
                                          • E
                                            escc1986
                                            think you could still help me , im just a noob at this and it shoulnt be that hard .
                                            ok ... i encounter another issue
                                            i entered Dosbox command
                                            the keyboard is typing different keys ... so the keyboard is messed up
                                            here is my config file for dosbox
                                            https://dropmefiles.com/gvDUp
