    Request : Help on Dos box
    dosbox
    42 Posts 3 Posters 4.9k Views
    • E
      escc1986
      ok if i made a new image by myself ... and encounter this same problem ... would you help me ... when i get to that point
      • quicksilverQ
        quicksilver @escc1986
        @escc1986 said in Request : Help on Dos box:
        think you could still help me , im just a noob at this and it shoulnt be that hard .
        ok ... i encounter another issue
        i entered Dosbox command
        the keyboard is typing different keys ... so the keyboard is messed up
        here is my config file for dosbox
        https://dropmefiles.com/gvDUp
        All of the issues you are having is because you are using a third party image. There is no way to know what settings the image creator messed with, which means we have no baseline for troubleshooting. I'm sorry but I don't want to spend all day trying to blindly troubleshoot your third party image.
        • quicksilverQ
          @escc1986 if you start with a stock image I would gladly assist you
          • E
            escc1986
            Thank you ... appreciate that .. that ok let me create a new image and try
            • E
              escc1986
              do i have to post a thread , so you guys can delete this one ?
              • E
                escc1986
                please delete this thread as it was a waste of time , and im sorry .. just learned something new and i appreciate it
                  mitu Global Moderator @escc1986
                  We don't usually delete topics just because someone used an unsupported system, even if they seem like a waste of time/bits. Don't worry about it, just don't come back using another 'made' image - start with the image from retropie.org.uk/download and follow the docs to install and configure it.
                  • quicksilverQ
                    @escc1986 once you get the official image set up feel free to continue using this thread to troubleshoot setting up your dos game.
                    • E
                      escc1986
                      Thank you both , and yes i do apologize for any incovience i may have cause ... i will use a new image next time , i talk with you guy
                      thank you for the lesson learned
                      • E
                        escc1986
                        Ok I'm back ... From the start
                        For some reason there isn't any news or Help on the Subject of Willy Bemish (CD) Talkie and in the Compatible list , it's not listed
                        When trying to install the game I get
                        "Error creating Configuration file"
                        Yes I mounted the ISO
                        By going into dosbox and typing
                        imgmount c "/home/pi/RetroPie/roms/pc/willy /willy.iso" -t iso -fs iso
                        It said mounted
                        And I typed
                        C:
                        C:install Willy.exe
                        It takes me to the install method
                        When I typed drive C and press install (in the install menu)
                        It says
                        Error creating configuration file (press any key to exit)
                        Is it possible for this game to work ?
                        Hope your able to help
                        Thank you
                        quicksilverQ 2 Replies Last reply Reply Quote 0
                        • quicksilverQ
                          @escc1986 it should run on dosbox just fine. Let me see if I can get it running and then I'll report back to you
                          • quicksilverQ
                            @escc1986 btw you can't install the game to drive C: because you already mounted your iso there. In other words you should imgmount to D: if you are going to install to C:
                            • E
                              escc1986
                              Hi quicksilver
                              Nice to hear back from you
                              It should run fine , Thank you letting me know , I was having doubts
                              Yes , I would love to hear if you got it working , I would appreciate that a lot , thanks for for going to test it out
                              I having had luck
                              And ok I will follow your direction with installing it to the D drive instead of C
                              If you get it to work , hope you can make me a step by step guide
                              Thank you once again
                              • quicksilverQ
                                @escc1986 so try installing the game by following the commands you used above but instead of
                                do:
                                imgmount d "/home/pi/RetroPie/roms/pc/willy /willy.iso" -t iso -fs iso
                                Then when it asks for the install location, choose C:
                                once the game is installed the easiest way of running the game will be to make a .conf file for the game. Create a blank file named nameofgame.conf (name Willy or willy beamish or whatever as long as it is .conf extension). In the .conf file create a section that looks like this:
                                [autoexec]
                                # Lines in this section will be run at startup.
                                mount c "/home/pi/RetroPie/roms/pc/"
                                imgmount d "/home/pi/RetroPie/roms/pc/willy/willy.iso" -t iso
                                c:
                                cd willy
                                willy.exe
                                Obviously make sure that the file paths I listed above actually are the same as what is on your pi, if they arent the same then change what I wrote above so that they point to the right file correctly. Also make sure that you use upper/lower case exactly too.
                                • E
                                  escc1986
                                  Wow you got it to work !!!! , that's amazing
                                  I'm going to try to give it a go
                                  Thanks for the simple instructions
                                  If I get stuck I will inform you
                                  Thank you once again for the instructions, means a lot
                                  • E
                                    escc1986 @quicksilver
                                    @quicksilver
                                    Hi quicksilver
                                    Did you get the game working ?
                                    I tried and I tried to follow your directions exactly how you instructed me
                                    I'm not sure what I did wrong
                                    The last try I attempted ,Froze my system
                                    I would try to boot my Pi back up and it wouldn't get to the main retropie menu it hanged and froze at command
                                    It made a dynamix folder in the Willy folder
                                    Had to delete that folder with every other thing thing that had to do with Willy to get the main menu on boot
                                    This games seems actually seems so weird to get running compared to other games
                                    Any more advice you may share with me ?
                                    • quicksilverQ
                                      @escc1986 are you using the stock pi image?
                                      • E
                                        escc1986
                                        Yes using the stock image
                                        I guess I must be doIng something wrong
                                        I must try again later today
                                        Well let me ask you ...
                                        When you start dosbox
                                        Do you first
                                        mount C
                                        Then
                                        Do the Imgmount
                                        Because when I first did the imgmount , and tried to install it said that there was no C drive to install to
                                        But when I did mount C first , then the imgmount it allowed me to install it on C
                                        Please verfy what I should be doing first
                                        I have the right steps but maby in doing them in a different order ?
                                        • E
                                          escc1986
                                          Wheni mentioned imgmount
                                          You know I'm referring to
                                          Imgmount D
                                          • quicksilverQ
                                            @escc1986 yes sorry you should
                                            First, then imgmount the iso to the d drive
