    PS4 controller build with 5 inch display
    retropiehandheldportable buildsraspberrypi 3b
    14 Posts 3 Posters 2.3k Views
      mud2005
      This is my 2nd build, first is shown here: https://retropie.org.uk/forum/topic/24530/handheld-with-7-inch-screen-finished
      I wanted something that was quick and easy this time, so I made this one as simple as possible. No case for the screen, no speakers...
      Next time I will use clear acrylic for the piece that covers the ps4 charging light, I used black because that's all I had at the time.
      I basically recreated the plastic piece on the back of the controller out of acrylic, drilled a couple holes in it and screwed it from the inside to another piece on the outside. That's what I attached the hinge to. It feels really solid and works great, but it is a bit top heavy due to the screen + battery weight.
      I'm going to make another one with a 3.5 inch display and try to move the battery inside the controller, hopefully that takes care of the weight issues.
      Also I need a screwdriver to loosen and adjust the hinge, going to replace the screws with something I can loosen by hand.
      Other than those issues it's super quick and easy to make and damn fun to play :)
      • IceChes1I
        IceChes1
        Ordering parts for a build like it.
        HOME CONSOLE
        Pi 4
        SanDisk 64 GB
        Master branch install
        3.5 amp CanaKit PSU
        Logitech F310, Dell keyboard, Dell mouse, JetFlash Transcend 16 GB USB stick
        HANDHELD
        Pi 0 W
        SanDisk 32 GB
        Random image I found. Had a driver I needed.
        IPEGA PG-9157 USB Receiver
        • IceChes1I
          IceChes1
          That's cool. Check out the thread in my signature, as I'll probably need assistance with the one I'm building.
          HOME CONSOLE
          Pi 4
          SanDisk 64 GB
          3.5 amp CanaKit PSU
          HANDHELD
          Pi 0 W
          SanDisk 32 GB
          • IceChes1I
            IceChes1
            What scree was used?
            HOME CONSOLE
            Pi 4
            SanDisk 64 GB
            3.5 amp CanaKit PSU
            HANDHELD
            Pi 0 W
            SanDisk 32 GB
            • IceChes1I
              IceChes1
              *screen
              HOME CONSOLE
              Pi 4
              SanDisk 64 GB
              3.5 amp CanaKit PSU
              HANDHELD
              Pi 0 W
              SanDisk 32 GB
                mud2005
                I used: https://www.amazon.com/gp/product/B013JECYF2/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
                I tried the drivers they recommended, didn't work.
                Download the driver from github then execute the following command
                chmod -R 755 LCD-show
                cd LCD-show/
                sudo ./LCD5-show
                ^ The above did not work^
                I used this and it worked:
                in /boot/config.txt
                dtparam=audio=on
                gpu_mem_256=128
                gpu_mem_512=256
                gpu_mem_1024=256
                overscan_scale=1
                hdmi_force_hotplug=1
                max_usb_current=1
                hdmi_drive=1
                hdmi_group=2
                hdmi_mode=1
                hdmi_mode=87
                hdmi_cvt 800 480 60 6 0 0 0
                dtoverlay=ads7846,cs=1,penirq=25,penirq_pull=2,speed=50000,keep_vref_on=0,swapxy=0,pmax=255,xohms=150,xmin=200,xmax=3900,ymin=200,ymax=3900
                display_rotate=0
                I haven't tried the touchscreen yet, but in the reviews I found this to install the calibration tool:
                sudo apt-get install xinput-calibrator
                I got this info from the first review on Amazon
                • IceChes1I
                  IceChes1
                  HOME CONSOLE
                  Pi 4
                  SanDisk 64 GB
                  3.5 amp CanaKit PSU
                  HANDHELD
                  Pi 0 W
                  SanDisk 32 GB
                  • V
                    VictimRLSH
                    Much cleaner build than my controller mount, great job!!!
                    System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
                      mud2005
                      Thanks, I realized a few things recently so I'm going to make some more changes.
                      To reduce the overall weight I can remove the rumble motors and battery from the controller, and the ethernet port and 2 of the USB ports from the PI.
                      Also to reduce the top heaviness I'm going to try and move the battery below the hinge instead of attached to the back of the screen.
                        mud2005
                        Well, I got the 3.5 inch display today: https://www.amazon.com/gp/product/B076M399XX/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
                        Has some pretty bad diagonal tearing, I'm probably just going to return it and use the 5 inch display.
                        • V
                          VictimRLSH
                          I'd recommend the Pimoroni Hyperpixel 4.0 it comes in touch and non-touch version, my controller mount uses it and it is SUPER bright (I can play in full sunlight) 800x600 resolution. It uses the GPIO pins instead of HDMI and the footprint is about the same size as the Pi 3 itself. I think the power draw is only around 150mA.
                            mud2005
                            awesome, thanks! I looked at that one when buying the 3.5 and didn't know if it would be as good considering it's not HDMI, so I went with the 3.5
                            only 150mA is awesome!! I'll order one of those and give it a try
                              mud2005
                              @VictimRLSH Got my hyperpixel 4 in the mail today, this is the display I've been looking for, the quality is excellent, small text looks very crisp, the color is beautiful, and the viewing angle is much better than some other displays I've used. Thanks for the recommendation!
                              V 1 Reply Last reply Reply Quote 1
                              • V
                                VictimRLSH @mud2005
                                @mud2005 Glad you like it too! The newer model is slightly squarer than the older ones and the resolution is a bit different, you might have an even better one.
