    WWF DOS Rom won't load. Can't find CD in Drive D
    dosboxcd drive dwwf in your houerrorload
    6 Posts 3 Posters 864 Views
      BTE2000
      Hi all. I'm trying to get WWF in your house for dos to load but I'm having trouble. It begins to load in dosbox until I get this error:
      "Function: copy_check
      Can't find the WWF in your house CD in drive D...
      Partial install requires WWFIYH CD-Rom for network play
      Press any key to exit"
      Any help would be greatly appreciated as I am new to dosbox and I've tried for hours just to start this game.
      • quicksilverQ
        quicksilver
        you need to imgmount the CD image to drive D: before trying to run the game. Easiest way of doing this is setting up a .conf file to launch your dos games. This will save you time so that you dont have to type out launching instructions each time you want to load a game.
          BTE2000 @quicksilver
          @quicksilver Thank u for Answering! How exactly would I go about doing this? Is this done onto the micro sd or from dosbox itself. Sorry I'm pretty much a noob when it comes to dosbox.
          Also what file is the cd image file
          mituM quicksilverQ 2 Replies Last reply Reply Quote 0
            mitu Global Moderator @BTE2000
            @BTE2000 You need to run the imgmount command from inside dosbox. The CD image file should come from your installation kit or your game copy - you can rip the CD image to an .iso file which can be read by `doxbox.
            • quicksilverQ
              quicksilver @BTE2000
              @BTE2000 This is quite the rabbit hole so bare with me :)
              So firstly I would recommend creating a separate folder within your /roms/ directory to put all of your Dos game files in. Currently you have everything in /roms/pc. I would recommend creating a folder in /roms/ called "pc2" or "pcgamefiles", it doesnt matter what its called. This way it keeps all the multitude of game files out of the /roms/pc folder. Then your launching .conf files will go in /roms/pc. This way you have just one file displayed for each dos game and things will look much tidier.
              Second, youll want to create a blank document in /roms/pc titled: nameofgame.conf (name it whatever you want). In the blank document you'll want to create a section that looks like this:
              [autoexec]
              # Lines in this section will be run at startup.
              @echo off
              mount c "/home/pi/RetroPie/roms/gamefilesfolder/"
              imgmount d "/home/pi/RetroPie/roms/path/to/image.iso" -t iso
              c:
              cls
              cd nameofgamefolder
              game.exe
              exit
              So what this is doing is executing commands for you, so that you dont need to type them out each time you launch a game. Each of those commands needs to properly point to the correct directories on your pi for the game to work so make sure you modify what I posted above. Upper/Lower case matters as well so pay attention to that.
              B 1 Reply Last reply Reply Quote 2
                @quicksilver Thank you so much!! I'm gonna give this a try now. Looks like alot but I'll try my best and let you know if I got it working
