    ACT LED blinks ONCE. Did I brick my Pi 4?
    pi 4 bricked
    8 Posts 2 Posters 257 Views
    • V
      VictimRLSH
      I was installing the Pi 4 on standoffs inside a case I'm making and tried to boot it (I check hardware at each stage of a project to make sure it still works). I get a single short blink on powerup with no video output.
      I've checked the resources here, https://www.raspberrypi.org/forums/viewtopic.php?t=58151 but one short blink is not mentioned here, which makes me believe I scraped something with a tool and broke a trace or something else fatal to the hardware. Inspection under a 3x magnifier isn't showing any broken traces or components shoved off their pads.
      System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
      • quicksilverQ
        quicksilver @VictimRLSH
        @VictimRLSH have you tried re-imaging or a different SD card?
        • V
          VictimRLSH
          Did that, no go. I also tried booting it with no card, a Pi 4 should blink 4 times with no card, but it still just blinks once and goes silent.
          • quicksilverQ
            @VictimRLSH can you remove from the case and try booting?
            • V
              VictimRLSH @quicksilver
              @quicksilver Also did that, my theory was a standoff displaced a surface mount part from its pad, but didn't actually see any evidence of that. It was running 30mins earlier when I checked it before mounting.
              • quicksilverQ
                @VictimRLSH I would still try with a fresh image on a different SD card just to be sure. If that doesn't work then I would say it's done for.
                • V
                  VictimRLSH
                  Not a huge loss, these things are cheap. Just chaffes my ass thinking I did something dumb and don't really know what it was. LOL
                  • V
                    VictimRLSH
                    Replacement arrived and is working in my prototype"Switch" case (almost finished!). However, why did I have to reset my Wi-Fi password if I used the same SD card from an identical Pi 4? It is encrypted with the processor ID?
