    Inconsistent volume across emulators
    2 Posts 2 Posters 1.2k Views
      taa800
      When I play different emulators on my Retropie setup (v3.6) some emulators are louder than others (especially N64). Is there a way to normalize the volume so it is always at the same level regardless of the emulator I'm playing?
        mediamogul Global Moderator @taa800
        @taa800
        I don't believe there is any way to handle this without first learning a bit about how audio is handled at a system level. However, a more immediate solution might be found right in your television. If it was produced in the last ten years or so, this type of functionality is commonly found by surfing through the audio setup options. Every manufacturer names this feature something different, so be sure to keep a keen eye out.
