    USB Flash Drive
    retropie-setup
    8 Posts 2 Posters 377 Views
    • E
      Eastonbosco
      USB Flash drive to copy config files
      Not able to copy rom and config file structure off Raspberry pi. Usb fat32 with Retropie dir, Using Retropie-4.5.1.rpi2_rpi.img. When usb is placed in the Pie nothing happens, Have tried several usb's. HELP!
        @Eastonbosco said in USB Flash Drive:
        An USB flash drive can be used for ROMs, there are no scripts to copy (to/from) the configs to USB. What exactly are you trying to do ?
        • E
          Eastonbosco
          Was trying to structure the usb flash drive with the Pie and then transfer the roms from my iMac to the usb, Then using the usb to install roms on the raspberry Pie, The whole process was to transfer roms from iMac to Pie. Help
            Did you follow the steps in the Docs exactly ?
            • E
              Eastonbosco
              Yes, formatted USB to FAT32,Created a folder caller RetroPie, Plugged it into the RetroPie system and nothing happens, I also tried another USB stick nothing, System did load up to emulation station and a controller was configured, Now nothing,
                mitu Global Moderator @Eastonbosco
                @Eastonbosco Check if the usbromservice is installed, from the RetroPie-Setup menu, it should be in the Core packages section.
                • E
                  Eastonbosco
                  Could not find usbromservice in the core package section, main packages or optional packages, Probably noticeable but i am a newbie to retropie and working with computers, I did download the retropie image and manage to get it installed on the pie, i also have a few roms downloaded on my iMac but unable to get them transferred over to the Pie, The whole process looked very easy on the video i watched, looks are deceiving. Thanks again Bob
                    The usbromservice is the last one in the Optional section (sorry, it's not in the core packages).
                    If you Raspberry Pi is connected to your network, you can easily transfer ROMs via file shares from your mac, see https://retropie.org.uk/docs/Transferring-Roms/#samba-shares, you don't need an USB drive.
