    Elegant Power On / Off
    22 Posts 8 Posters 31.2k Views
      battlecat
      Hello:
      Is there an elegant solution to power the RPi on and off? I do nto want to get my RetroPie all set up only to have the SD card die from corruption.
      Ideally I would like to have a simple accessible button on the arcade cabinet to turn the system off and on elegantly.
      Thank you,
      Richard
        GtBFilms
        Powerblock!
        I ordered mine from:
        http://blog.petrockblock.com/2015/07/04/powerblock-another-power-switch-for-the-raspberry-pi/
        Including postage it came to £18.74 and took exactly 3 weeks to arrive from Germany.
        The PowerBlock works with the original Pi, the Pi 2 and the Pi 3, it basically adds a power switch to the Pi, so:
        i) It doesn't power up the minute you plug it in
        ii) You don't have to pull the plug from the wall and plug it back in to start the Pi after it has been shut down.
        iii) You don't have to use the menu system to cleanly power down the system, you can do it from a button
        It supports an LED to indicate the state of the Pi - booting up (slow flashing), on (steady light), shutting down (rapid flashing), and off (off). When shutting down it cleanly shuts down the RPi before it cuts the power.
        It doesn't come with any switch or LED, to keep costs low. It should work with any toggle, or latching button, but NOT a momentary button.
        I'll try an upload some photos.
        Http://www.gtbfilms.co.uk/misc_photos/powerblock.jpg
        Http://www.gtbfilms.co.uk/misc_photos/powerblock_on_rpi.jpg
        Http://www.gtbfilms.co.uk/misc_photos/inside_picade.jpg
        Http://www.gtbfilms.co.uk/misc_photos/picadeback.jpg
        The details are all on the Petrock Web page, you need to run a couple of installation commands, it's quite straightforward.
        I constructed this illuminated latch button solution for a couple of £s:
        Http://www.gtbfilms.co.uk/misc_photos/cable_with_labels.jpg
        Http://www.gtbfilms.co.uk/misc_photos/led_latch_button.jpg
        Because it's a latching button, you can't use the menu system to shutdown any more - the button is still ON, so it shuts down and boots right back up again - you basically HAVE to use the button for starting/shutting down once it's installed. But that's why you wanted it in the first place, right? ;-)
        CapemanC 1 Reply Last reply Reply Quote 2
          battlecat
          Hello GtBFilms:
          Thanks for the info. Some photos would be awesome. I had read about this but to be honest I wasn't really sure what it did after reading about it.
          Thanks and looking forward to the photos.
          -bc
          GtBFilmsG 1 Reply Last reply Reply Quote 0
            GtBFilms @battlecat
            @battlecat No problem, hopefully these links I just added will work.
            If you are interested in the full build (Pimoroni picade cab), feel free to have a look our Edinburgh Retro PC club forum (www.edinburghretropc.co.uk) where we have a section on MAME cabs of all shapes and sizes built by club members - sorry but we had to add a sign-up thing for access, because of all the spamming, but if you request a login, someone will grant access.
            Or here's a video clip of it working, before I mounted the button in the back door of the cab.
            Http://www.gtbfilms.co.uk/misc_photos/powerswitch.mp4
              battlecat
              Hi:
              Sadly those links do not seem to be working. Can you repost them?
              I just did the registration for the forum. Thanks for that.
              I have a cabinet already built but love looking at what others do.
              -BC
                GtBFilms @battlecat
                @battlecat
                Sorry about that, I've just moved my web hosting and don't really know what I'm doing with the new one yet.
                I've updated them now, hopefully they will work. Or they are on our website and also in our 'Edinburgh Retro PC' Facebook group.
                  battlecat @GtBFilms
                  @GtBFilms OMG! That is what I want! It is what I have been searching for for the last 2 weeks! And here you have a video of it in action.
                  What gods do I have to battle and defeat to get more instructions on how you achieved this!?
                  LOL
                  Thanks again,
                  BC
                  B GtBFilmsG 2 Replies Last reply Reply Quote 0
                    battlecat @battlecat
                    @battlecat So that uses the power block you bought for ~20 euros ? I will need to get one of them.
                    darthpaulD 1 Reply Last reply Reply Quote 0
                      battlecat
                      So I am looking at the powerblock site and I see that it does not list the Pi3 as an option
                      The PowerBlock is an add-on board for the Raspberry Pi (version 1 and 2) models A+ and B+. It provides a microcontroller-based power-switch functionality.
                      Any ideas if it will work with the Pi3?
                      --BC
                      P GtBFilmsG 2 Replies Last reply Reply Quote 0
                      • darthpaulD
                        darthpaul @battlecat
                        @battlecat I have been using a Mausberry Circuit
                        http://mausberry-circuits.myshopify.com/ works like a charm.
                          PaulCheffus @battlecat
                          @battlecat
                          Hi
                          I can't see any reason why not unless the actual device that does the switching isn't rated high enough for the power consumption of the Pi3. Personally I use an ATXRaspi for mine which also powers the screen along with the Pi3 in a Picade cabinet.
                          Cheers
                          Paul
                            GtBFilms @battlecat
                            @battlecat said in Elegant Power On / Off:
                            the Pi3?
                            Hi, yup, I wondered about this too.
                            When you go to purchase it via the link to the Storenvy site though, the Pi3 is listed as compatible. Which is why I went ahead and bought it.
                            And I can confirm it works fine with my Pi3!
                            It only switches the 5V power to the Pi though, as someone mentioned above, if you power the screen separately, because it's a larger screen requiring 12V, or for some other reason you aren't powering the screen from a Pi USB slot, then this solution won't turn off your screen at the same time.
                              GtBFilms @battlecat
                              @battlecat
                              Glad you like the PowerBlock, I'm quite impressed with it (not affiliated with the manufacturers!)
                              It doesn't come with a button or a light though, you have to make your own.
                              You need to provide a toggle or latching switch (that basically stays on or off when pressed), not a momentary switch (which just sends the press signal while actually pressed down).
                              I decided to get an illuminated (green) latching button, to combine the switch and LED in the one button. I wired it up using some old connectors I cannibalised out of a PC case I was throwing away.
                              Because Maplins charge £3.19 for ONE illuminated button, and the PowerBlock takes about 3 weeks to arrive from Germany, I sourced my button from China - I got FIVE for £2.43, delivered!
                              So I basically have five times more than I need. I made 3 buttons up with cables and a resistor to reduce the voltage to the 3V needed for the LED (apparently this is no longer actually required with the latest PowerBlock design but does no harm). Then I ran out of cable and pin connectors.
                              I've already used one of the buttons obviously, and I just sent one of the others to a guy in the States.
                              If you're going to get a PowerBlock and want my last button and cables for it (free), let me know your mailing address and you can have it. I don't know how to PM on here, but you can email me at GtB at the domain I uploaded the video clip/photos to.
                              Unless you intend to just have the button hanging loose in the case, you'll have to drill a 15mm (I think) hole for it. It comes with a fixing ring that screws on the back and secures it in place.
                              • GreenHawk84G
                                GreenHawk84
                                Would I use a PowerBlock if I plan to shut my system off through the menu each time in my arcade cabinet? I will shut it down manually and then cut main power while the Pi is lit in "standby." I just have a main power switch in the back which is connected to the power strip in the cabinet.
                                  GtBFilms @GreenHawk84
                                  @GreenHawk84
                                  No, I don't think PowerBlock would necessarily be the best solution if you still want to shut down the system from the menu each time. Because Powerblock needs a latching/toggle button when you shut down from the menu, the button is still on, so the pi immediately starts back up again. There is a very short amount of time where the pi is in "standby' .
                                  However you could shut down the Pi using PowerBlock (not the menu), wait until it shuts down, then cut main power once the shut down is complete. It does mean you'd have a two-step process every time you switch on/off the cab though.
                                    PaulCheffus @GtBFilms
                                    @GtBFilms said in Elegant Power On / Off:
                                    @GreenHawk84
                                    Hi
                                    I use an ATXRasPi to power my cabinet which uses a momentary switch. I have an Opto Isolator (you could also use a BC337 transistor) across the switch terminals. The input to the Opto is driven from a GPIO pin. The GPIO pin is driven by a script which is in turn called by the script EmulationStation.sh that runs when you select shutdown or restart from the menu. This allows me to shut the cabinet down either via the switch or the menu.
                                    This method wouldn't work with the PowerBlock due to it using a latching switch.
                                    Cheers
                                    Paul
                                      movisman
                                      @GtBFilms
                                      Hi there,
                                      I've been thinking of getting myself a Powerblock to use in my Picade for graceful boot/shutdown, am looking to do exactly what you have achieved and mount the button on the back of the cabinet. Did you have any issues with it or was it all straightforward enough? From the reading I have done it all looks relatively simple.
                                      Also, cheeky question but is your last button/cables still up for grabs?
                                      Cheers!
                                        GtBFilms @movisman
                                        @movisman
                                        I didn't encounter any problems. Hardest part was drilling a hole in the back door to fit the button.
                                        Yeah, I still have the last one (I made 3) if you want it, you can have it, no problem.
                                        Email me your details at picade at gtbfilms dot co dot uk
                                          movisman @GtBFilms
                                          @GtBFilms
                                          Hi,
                                          That's great, yeah I was planning to put the button pretty much where you've put yours, I will just need to get hold of the relevant drill bit to make a tidy hole.
                                          Thanks so much for offering to give away your third button/cable, that's very generous. I will drop you an email shortly.
                                          Cheers!
                                          • AndersHPA
                                            AndersHP
                                            Just reliving this old topic.
                                            I'm curious as how to this 'elegant power button' solutions work when you power on/off the main power also.
                                            My build is based on a hardcore power on/off switch at the back, meaning that when I power on, everything gets 230V and boots up.
                                            Since I will be moving my bartop arcade around, I'd like to know how these buttons react when you do a power cycle on the mains power? Does it turn on instantly, or just await dormant till you push the "elegant power button"?
                                            I ask since I was thinking of making my marquee and button light work alongside a 12v fade-in/fade-out dimmer, to give the build a bit more elegant and luxury feel to it, and it would kind of ruin the idea if it requires constant power, and make the elegant bootup with fading lights redundant after I have killed the mains power, since I probably will be doing this half the time.
                                            My Gameboy
