    PSX_rearmed: Diablo-Sound Fix
    psx-rearmed
    5 Posts 2 Posters 668 Views
    • sirhenrythe5thS
      sirhenrythe5th
      Hi Folks,
      may be a dumb question :)
      I just read on GitHUB that the Diablo-Sound"Fix" is not a real fix - it is a hack.
      My question is: is it possible to activate this hack in retroarch/settings or ~/configurations to be enabled only when playing Diablo?
      I had a look in "configurations" of retroarch but did not find an option like "save for this game".
      Or does this hack not disturb any other games and can be set global for eternity?
      RetroRatio: 1.91
      Started Games beaten: 2,40%
        @sirhenrythe5th said in PSX_rearmed: Diablo-Sound Fix:
        Isn't this in the 'Options' menu, where you have the 'Create Game Options' entry ?
        • sirhenrythe5thS
          sirhenrythe5th
          i see….
          i am not sure if i had a look in "options" - will do that in the evening - thank you for pointing me in that direction!
          Just another question: at the moment the DiabloSOund-Hack ist enabled global in lr-PSXreARMed because i have acitvated the automatic saving in "Configurations -> save on Exit".
          Will this setting override my saved-options per game?
          So do i have to deactivate the autosaving of the configuration-file before if i want to save options for one dedicated game?
          RetroRatio: 1.91
            mitu Global Moderator @sirhenrythe5th
            Options are not saved in the RetroArch configuration file, they're in a separate config. You can change the options for the game you want, then create the options file for it, then revert the options changed if you don't want that to be applied to all games.
            No, per-game core options are applied, if exist.
            As I said, Core Options are saved separately. They're automatically saved, so nothing needs to be enabled in RetroArch. I'd advise against using 'Save on Exit' though for RetroArch.
            • sirhenrythe5thS
              sirhenrythe5th
              Got it!
              Thank you very much @Mitu!!
              RetroRatio: 1.91
