    Retropie PSX Emulator only 1 controller works
    34 Posts 5 Posters 16.8k Views
      meleu @dankcushions
      @dankcushions said in Retropie PSX Emulator only 1 controller works:
      @meleu then how would you launch the fixed version? :) by editing the existing .sh you can launch it via retropie-setup.sh as normal.
      Well, if the copied script is at RetroPie-Setup/scriptmodules/libretrocores/, as the original file, it will be launchable via retropie_setup too. BUT... I have to agree that my suggestion is incomplete, therefore unusable...
      The functions inside the copied script need to be renamed to match the file name... although this renaming process could be simple for a experienced sed or vim user, it's simpler to just follow your instructions (edit the URL and after the reinstall put back the libretro one).
      Sorry guys...
        trying to repair my mistake... :-)
        A simple module to install the @alexis-puska fixed version: https://raw.githubusercontent.com/meleu/RetroPie-Setup/master/scriptmodules/libretrocores/lr-pcsx-rearmed-puska.sh
        [EDIT: the @alexis-puska Pull Request was merged! No need to use this anymore!!]
        Installation method
        wget -O ~/RetroPie-Setup/scriptmodules/libretrocores/lr-pcsx-rearmed-puska.sh \
        Then, start retropie_setup.sh and go to Manage Packages -> exp -> lr-pcsx-rearmed-puska -> Install from source.
        Benefits of this method
        It installs the @alexis-puska version and let the original lr-pcsx-rearmed.sh untouched. It installs another emulator option for Playstation. Choose it in the runcommand menu.
        Hope it helps!
          edmaul69 @meleu
          @meleu if i go to the website your file exist, but on the pi it says no such file exist when i use the commands above.
            meleu @edmaul69
            @edmaul69 can you paste the error message?
              edmaul69 @meleu
              @meleu said in Retropie PSX Emulator only 1 controller works:
              it says no such file or directory
              root@retropie:~# wget -O ~/RetroPie-Setup/scriptmodules/libretrocores/lr-pcsx-rearmed-puska.sh \ https://raw.githubusercontent.com/meleu/RetroPie-Setup/master/scriptmodules/libretrocores/lr-pcsx-rearmed-puska.sh
              /root/RetroPie-Setup/scriptmodules/libretrocores/lr-pcsx-rearmed-puska.sh: No such file or directory
                meleu @edmaul69
                @edmaul69 you are using the root user dude!!
                You have to do it as the pi user!
                edmaul69E 2 Replies Last reply Reply Quote 1
                  edmaul69 @meleu
                  @meleu pi user. Check. :) i always log in as root.
                    edmaul69 @meleu
                    @meleu works! Thank you.
                      meleu @edmaul69
                      @edmaul69 just to explain what went wrong:
                      The tilde ~ symbol means $HOME. Then, if you are root, your home directory is /root. And if you are pi, your home directory is /home/pi.
                      Do you get it?!
                        edmaul69 @meleu
                        @meleu that would explain a lot. I always had to type out the directory i wanted because ~ did absolutely nothing for me. I always wondered why everyone has that but it never once worked for me.
                          meleu @edmaul69
                          @edmaul69 The @alexis-puska Pull Request was merged!! You can uninstall the emulator installed with the lr-pcsx-rearmed-puska.sh.
                          RetroPie-Setup -> Manage Packages -> exp -> lr-pcsx-rearmed-puska -> Remove
                          I'm glad my script lived only 3 days but it was enough to make you understand that ~ means $HOME. :-)
                            edmaul69 @meleu
                            @meleu and i am so glad to know to ssh into it as pi. Saves me the headache.
                              alexis-puska
                              @edmaul69 Thank's to you for this work around with this script.
                                edmaul69 @alexis-puska
                                @alexis-puska that was @meleu that provided the workaround.
