    Problem to mount HFS+ HDD with RetroPie
    hfs+fstabmount usbmountmount drive
    6 Posts 2 Posters 597 Views
    • iMacosirisI
      iMacosiris
      Hi guys
      Hope you can help me with this
      I have my RetroPie configure with an USB stick and USB HDD (the disk has HFS+ format)
      I follow this guide to move the roms : https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive
      All works great, but I like to mount the disk and add the info in the fstab so I follow the same link ( https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive)
      but I got an error when I try to boot after I change my fstab.
      I see other post and I fix the HFS+ journal
      This is the current info in my system
      pi@retropie:~ $ ls -l /dev/disk/by-uuid/
      total 0
      lrwxrwxrwx 1 root root 10 Apr 25 04:17 1D8D-D42B -> ../../sda1
      lrwxrwxrwx 1 root root 10 Apr 25 04:17 36e09f00-1197-377f-8f97-0901843273f0 -> ../../sdb1
      lrwxrwxrwx 1 root root 10 Apr 25 04:17 b5bfbb14-56d1-4eab-a831-0d17cd711a6a -> ../../sda2
      pi@retropie:~ $ sudo lsblk -o UUID,NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL,MODEL
      UUID                                 NAME   FSTYPE    SIZE MOUNTPOINT  LABEL    MODEL
                                           sda             28.7G                      Ultra Fit
      1D8D-D42B                            |-sda1 vfat      240M /media/usb1 boot
      b5bfbb14-56d1-4eab-a831-0d17cd711a6a `-sda2 ext4     28.4G /           retropie
                                           sdb            931.5G                      MQ01ABD100
      36e09f00-1197-377f-8f97-0901843273f0 `-sdb1 hfsplus 931.5G /media/usb0 ROMS
      pi@retropie:~ $ sudo blkid
      /dev/sda1: SEC_TYPE="msdos" LABEL="boot" UUID="1D8D-D42B" TYPE="vfat" PARTUUID="6397c987-01"
      /dev/sda2: LABEL="retropie" UUID="b5bfbb14-56d1-4eab-a831-0d17cd711a6a" TYPE="ext4" PARTUUID="6397c987-02"
      /dev/sdb1: UUID="36e09f00-1197-377f-8f97-0901843273f0" LABEL="ROMS" TYPE="hfsplus"
      pi@retropie:~ $
      As you can see I install and update all software for HFS+
      pi@retropie:~ $ sudo apt-get install hfsplus hfsutils hfsprogs
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      hfsplus is already the newest version (1.0.4-15).
      hfsprogs is already the newest version (332.25-11+b1).
      hfsutils is already the newest version (3.2.6-13).
      0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
      My fstab I have to comment the entry for the HDD
      proc            /proc           proc    defaults          0       0
      PARTUUID=6397c987-01  /boot           vfat    defaults          0       2
      PARTUUID=6397c987-02  /               ext4    defaults,noatime  0       1
      # a swapfile is not a swap partition, no line here
      #   use  dphys-swapfile swap[on|off]  for that
      #UUID=36e09f00-1197-377f-8f97-0901843273f0 /mnt/retrorom /home/pi/RetroPie      hfsplus    force,rw,nofail  0       0
      So my question is what I doing wrong ? should I need to disable the USB transfer daemon ?
      I confuse.
      Well hope some one can help me
      If you need more info just ask please !
      Thanks in advance
      Best Regards
        I think the line above is wrong, you have an extra entry (/mnt/retrorom) which shouldn't be there. Also, you should add the options to allow the pi user to write to the disk, otherwise you'll get permission errors.
        If you're using the manual method, then yes, should disable the service added by the usbromservice package.
        iMacosirisI 1 Reply Last reply Reply Quote 0
        • iMacosirisI
          iMacosiris @mitu
          @mitu Thanks a lot
          I finally got the disk mount , but now I see the error " WE CAN'T FIND ANY SYSTEM"
          I check and find the permission OK and I can write in the volume
          I can't figure why the system can't finds the rom
          pi@retropie:/ $ sudo lsblk -o UUID,NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL,MODEL
                                               sda             28.7G                            Ultra Fit
          1D8D-D42B                            |-sda1 vfat      240M /boot             boot
                                               sdb            931.5G                            035-1RK172
          67E3-17ED                            |-sdb1 vfat      200M                   EFI
          823e6ab6-188c-3ef0-bfac-8162cca79436 `-sdb2 hfsplus 931.1G /home/pi/RetroPie ROMS
          pi@retropie:/ $ df -h
          Filesystem      Size  Used Avail Use% Mounted on
          /dev/root        28G  6.7G   21G  25% /
          devtmpfs        244M     0  244M   0% /dev
          tmpfs           248M  4.0K  248M   1% /dev/shm
          tmpfs           248M  6.8M  241M   3% /run
          tmpfs           5.0M  4.0K  5.0M   1% /run/lock
          tmpfs           248M     0  248M   0% /sys/fs/cgroup
          /dev/sdb2       932G  266G  666G  29% /home/pi/RetroPie
          /dev/sda1       240M   23M  217M  10% /boot
          tmpfs            50M     0   50M   0% /run/user/1000
          my fstab
          UUID=823e6ab6-188c-3ef0-bfac-8162cca79436       /home/pi/RetroPie       hfsplus force,auto,uid=1000,users,rw    0       0
          I create a directory inside the /home/pi/Retropie with out any problem the owner inside RetroPie is the pi user
          Any ideas ???
          • iMacosirisI
            iMacosiris
            Also I remove the usbromservice to avoid any issue
              mitu Global Moderator @iMacosiris
              @iMacosiris said in Problem to mount HFS+ HDD with RetroPie:
              Did you copy the ROMs folders to the mounted partition ? If you disabled the usbromservice service, this doesn't happen automatically. You need to follow all the steps in the docs for manually mounting - one of which is the transfer of the $HOME/RetroPie contents to the USB folder partition.
              • iMacosirisI
                iMacosiris @mitu
                @mitu Thanks a lot with that final touch works !!!
                Thanks a lot for your help !
                Br
