    Noob help - RPi 3 ROMS not working....
    6 Posts 4 Posters 2.5k Views
      canned
      Hi all,
      I've spent days at this and searched all over but I'm still having trouble....
      I've installed RetroPie using an RPi 3, downloaded a big list of ROMs and had pretty much no success in getting them to work.
      I'm particularly interested in bobble bobble, donkey kong, pacman, frogger - all arcade games.
      I'm managing the ROMS by USB (plug it in, let it finish flashing, take it out, place roms in right directory) and they are showing up under the arcade menu but no matter what I do they won't run. I've tried making sure to check that they are on "imameforall" as this appears to be the advice from searches - and when that didn't work I went through changing to others but still no joy.
      There doesn't seem to be a "baby steps" guide - and writing one for the multitude of different things people would want to do is pretty impractical to be fair - but baby steps is what I need so if you can help it would be much appreciated!
      TC
      rbakerR thrussmeisterT 2 Replies Last reply Reply Quote 0
      • rbakerR
        rbaker @canned
        @canned
        Where have you been looking?
        You simply need to read:
        https://github.com/RetroPie/RetroPie-Setup/wiki/Managing-ROMs
        and make sure that
        a) You have the correct romset for the version of MAME
        It could be a random romset that you have with old or non-working versions! versions matter a lot as seen in the wiki link above.
        and
        b) You have the correct BIOS files if you decide to run individual ROMS.
        There is a guide and It's all been written for you:
        https://github.com/retropie/retropie-setup/wiki
        This will answer everything. Then you can watch
        tutorial to learn more about MAME.
        Good Luck!
        If anything doesn't work after following it, then
        • thrussmeisterT
          thrussmeister @canned
          @canned This is a tough one, So as @rbaker has said read the link it's very takes a while to get your head round I'm about two months in but simply each Emulator in your case "mameforall" your roms would need to be from the July 2000 release 0.37b5 if for example you went to a site a downloaded a mame Romset it would be like .164 this a high chance this wont work you need the right set for the right emulator. I use lr-Mame2003 so mine have to be the .78 romset . as a newbie it's quite hard to get your head round. Let me know if I can help...I've just gone through this. I think there is a private message function so if you want a detailed chat drop me a line and we can exchange emails.
            megatron99
            A lot is trail and error. keep reading forums and watch videos on You Tube.
            This site may be confusing to read but it will be a good starting point getting roms to work.
              canned
              @all... Starting to get my head around it now and hoping to get it going in the next few hours!
              Thanks for the replies!
              Tony
                canned
                finally got something running - installed for xbox360 controller but can't seem to use it with pacman or bombjack. more googling!
