Retropie 4.6 composite out issue flickers and freezes
Just installed new image on RPi4. Plug it through tv-out, edit config.txt (enable_tvout=1). Run a nes game through lr-fceumm and see some kind of flickers and freezes. everything is fine through hdmi. besides, I could not find retroarch render resolution settings in runncomand menu. how can i change it now?
@sexbeer said in Retropie 4.6 composite out issue flickers and freezes:
When you set
enable_tvout
, that comes with a performance penaltyhttps://www.raspberrypi.org/documentation/configuration/config-txt/video.md:
Because composite video requires a very specific clock, setting that clock to the required speed on the Pi 4 means that other clocks connected to it are detrimentally affected, which slightly slows down the entire system.
Can you post your entire
config.txt
?besides, I could not find retroarch render resolution settings in runncomand menu. how can i change it now?
I think it's not supported on the PI4.
# For more options and information see # http://rpf.io/configtxt # Some settings may impact device functionality. See link above for details # uncomment if you get no picture on HDMI for a default "safe" mode #hdmi_safe=1 # uncomment this if your display has a black border of unused pixels visible # and your display can output without overscan #disable_overscan=1 # uncomment the following to adjust overscan. Use positive numbers if console # goes off screen, and negative if there is too much border overscan_left=30 overscan_right=5 overscan_top=-10 overscan_bottom=-10 # uncomment to force a console size. By default it will be display's size minus # overscan. #framebuffer_width=1280 #framebuffer_height=720 # uncomment if hdmi display is not detected and composite is being output #hdmi_force_hotplug=1 # uncomment to force a specific HDMI mode (this will force VGA) #hdmi_group=1 #hdmi_mode=1 # uncomment to force a HDMI mode rather than DVI. This can make audio work in # DMT (computer monitor) modes #hdmi_drive=2 # uncomment to increase signal to HDMI, if you have interference, blanking, or # no display #config_hdmi_boost=4 # uncomment for composite PAL sdtv_mode=2 #uncomment to overclock the arm. 700 MHz is the default. #arm_freq=800 # Uncomment some or all of these to enable the optional hardware interfaces #dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # Uncomment this to enable infrared communication. #dtoverlay=gpio-ir,gpio_pin=17 #dtoverlay=gpio-ir-tx,gpio_pin=18 # Additional overlays and parameters are documented /boot/overlays/README # Enable audio (loads snd_bcm2835) dtparam=audio=on [pi4] # Enable DRM VC4 V3D driver on top of the dispmanx display stack dtoverlay=vc4-fkms-v3d max_framebuffers=2 [all] #dtoverlay=vc4-fkms-v3d gpu_mem=256 enable_tvout=1 disable_splash=1
I don't have my CRT TV at hand, but I did test the composite output (NES) and didn't notice any remarkable slowdowns. Will try to re-test, but what you can try:
- switch to 240p (
sdtv_mode=18
orsdtv_mode=16
) - enable the performance CPU governor in the Runcommand settings.
- switch to 240p (
@mitu thanks, but it didn’t help me. I tried different cables and settings to connect. and I can say with 100% certainty that my CRT TV and cables are in good condition. I also tried to connect to this TV using the HDMI2AV adapter. and everything was fine with him. It’s unfortunate that the connector exists, but its support is not :(
I'll try to re-test this week-end, maybe there is a regression in recent kernels/firmware. I wonder if playing a movie would exhibit the same symptoms.
mine has been freezing a lot I've even replaced many parts including using another pie 4 , sadly nothing seems to help. I hope there is a fix for whatever this is use is, ive wasted a entire day trying.
@sexbeer I tried a test with the Composite port as video/audio and I can't notice any slowdowns. I tested a few system - NES,Arcade,NeoGeo - and it's not noticeable.
Try running an OS update and re-test.
I changed some video settings in retroarch.cfg and now it's more playable.
video_hard_sync = "true" video_max_swapchain_images = "3" video_vsync = "false" vrr_runloop_enable = "true"
I don’t know how it works and what it affects, but it works at least with NES.
In the lower third of the screen there was a certain flicker, the picture seemed to twitch. Now the picture has become even too smooth, which is good news :) -
I have the same problem, I can solve it changing sdtv_mode=1 for use NTSC system instead mode=2 for PAL.
I prefer PAL colours but the flickers are awful!
