Can't adjust sound channels. One is TOO LOUD, the other too low.
I have a question about the RetroPie. I am running on Pi4.
When I use my two speakers, I get very loud sound on right channel, and very low on left.
When I check the sound card it only shows one channel? (PCM one bar only)
How do I make it so I can adjust both channels and level out the volume between them?
This Pi is running in a modified arcade cab running Mame and other emulators.
I have the output from Pi4 using HDMI to controller board (video) and 3.5mm cord running to
amp and two speakers connected to amp.
I also removed the POulse Audio as read on another forum it causes issues with the ALSA sound.
I am using the ALSA sound manager.
Thank you in advance.
