    master system
    joystick
    20 Posts 2 Posters 659 Views
      shura-3275
      hello everybody,
      I have a problem with the master system
      as soon as I enter the console to choose a game everything blocks and I can not do anything .... I am forced to turn off and on my raspberry. maybe a bios problem ??
        Please add more info about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
          shura-3275 @mitu
          @mitu raspberry 3b + with last updated retropie
            Please provide the complete info - what controller are you using, what emulator, what game are you running ?
              shura-3275 @mitu
              @mitu I use a ps3 style gamepad but not official
              my emulator how do i know ?? sorry but I'm new to this area.
              and this is not when I enter a game but a console (Master system) as soon as I enter the list of the master system, everything blocks
                mitu Global Moderator @shura-3275
                @shura-3275 said in master system:
                The name of the emulator is shown when the game starts, in the runcommand launch menu. But since this is not about launching a game, it's maybe not so important.
                What theme are you using ? Maybe the theme is too heavy for the PI - did you try with the default (Carbon) theme ?
                  shura-3275 @mitu
                  @mitu I use the theme "HEMAN"
                  I have not tested all the consoles yet but for the moment there is only the master system which bug
                  my console is no longer plugged in tonight.
                  tomorrow i will look for the emulator and i will try to change themes and tell you what's going on.
                  good evening and thank you
                    shura-3275
                    hello @mitu
                    Hello,
                    I looked for my emulator it is: emulationstation V2.9.1RP
                    and I tried the "CARBON" theme but it does the same.
                    I also have the same problem with N64
                      How did you install the system ? Did you use the image from retropie.org.uk/download or another image ?
                      Do you have video previews enabled in EmulationStation ?
                      EDIT: can you find the \\retropie\configs\all\emulationstation\es_systems.cfg file and post its contents here in the topic ?
                        shura-3275 @mitu
                        @mitu 1-yes I downloaded on retropie.org and install with win32diskimager.
                        2-what do you call video preview ??
                        3-how do I find the retropie / configs file ... ??
                        sorry but i am not yet familiar with all this
                          @shura-3275 How did you copy your ROMs over to the Pi ?
                          Did you use the file shares method described here ?
                          If you have a PC (with Windows installed), just open Windows file explorer and type \\retropie\configs\all\emulationstation\ in the location input. If asked for a user/password, use pi/raspberry. This should open a folder, where you can find the configuration file I asked.
                            shura-3275 @mitu
                            @mitu https://ibb.co/f9KPR2V
                            and then where should I go?
                              shura-3275
                              https://ibb.co/JFXDQfW
                              is that what you want?
                                Almost. I'm going to ask you again - what image did you use to install RetroPie ? This doesn't look like a stock image you would download from retropie.org.uk/download.
                                  shura-3275 @mitu
                                  @mitu https://ibb.co/5MnZt3P
                                    Somehow I'm not convinced you're running an official RetroPie image.
                                    • your system has a custom es_systems.cfg that's doesn't exist by default on a RetroPie stock image. You need to create one manually and copy it to the folder that you just had trouble opening.
                                    • if you'd have used the RetroPie image that your screenshots shows, you wouldn't had the login issue from the other topic you opened.
                                    As the https://retropie.org.uk/forum/topic/3/read-this-first states, we don't support 3rd party images.
                                      shura-3275
                                      the image is well downloaded on the site but considering what you tell me I think I know why ....
                                      the roms, bios etc ... come from a friend of which I have copy on my PC and after having downloaded the image I have copy roms, bios ..... on my raspberry via cable rj45.
                                      I also copied her configs, splashcreen. maybe I would only copy roms and bios and not the rest ???,
                                        shura-3275 @mitu
                                        @mitu is there a way to change something from "configs" or do you think i have to start from the beginning and insert only roms and bios ??
                                          I suggest you start with a fresh image and add your ROMs/BIOS files, leaving the configurations alone for this first step.
                                            shura-3275 @mitu
                                            @mitu said in master system:
                                            very well, that's what I'm going to do.
                                            thank you again for your help and your patient to answer me. thank you and good luck
