    No Sound 3.5mm Jack
    3 Posts 2 Posters 6.0k Views
    • fastlowrexF
      fastlowrex
      I have been running my retropie via HDMI connection to TV with no issues. I am now using a monitor with DVI connection and sound via 3.5 jack on the PI. The sound works for about a 1 minute or 2 then stops and will only work agin if I restart system. I have read forum post after forum post. I have change config files etc and every single thing I tried does not fix the issue. Please, please help! I am desperate.
      • fastlowrexF
        fastlowrex
        Here is my config:
        For more options and information see
        http://www.raspberrypi.org/documentation/configuration/config-txt.md
        Some settings may impact device functionality. See link above for details
        uncomment if you get no picture on HDMI for a default "safe" mode
        #hdmi_safe=1
        hdmi_ignore_edid_audio=1
        uncomment this if your display has a black border of unused pixels visible
        and your display can output without overscan
        disable_overscan=0
        uncomment the following to adjust overscan. Use positive numbers if console
        goes off screen, and negative if there is too much border
        #overscan_left=16
        #overscan_right=16
        #overscan_top=16
        #overscan_bottom=16
        uncomment to force a console size. By default it will be display's size minus
        overscan.
        #framebuffer_width=1280
        #framebuffer_height=720
        uncomment if hdmi display is not detected and composite is being output
        hdmi_force_hotplug=1
        uncomment to force a specific HDMI mode (this will force VGA)
        hdmi_group=2
        hdmi_mode=57
        uncomment to force a HDMI mode rather than DVI. This can make audio work in
        DMT (computer monitor) modes
        #hdmi_drive=2
        uncomment to increase signal to HDMI, if you have interference, blanking, or
        no display
        #config_hdmi_boost=4
        uncomment for composite PAL
        #sdtv_mode=2
        #arm_freq=800
        Uncomment some or all of these to enable the optional hardware interfaces
        #dtparam=i2c_arm=on
        #dtparam=i2s=on
        #dtparam=spi=on
        Uncomment this to enable the lirc-rpi module
        #dtoverlay=lirc-rpi
        Additional overlays and parameters are documented /boot/overlays/README
        Enable audio (loads snd_bcm2835)
        dtparam=audio=on
        gpu_mem_256=128
        gpu_mem_512=256
        gpu_mem_1024=256
        #overscan_scale=1
          PaulCheffus
          Hi
          Have you tried setting the audio to the 3.5mm jack in the RetroPie Audio settings?
          Cheers
          Paul
